how much to get driveshaft balanced?
  • Thread starter Thread starter Musclecarfan88
  • Start date Start date Aug 8, 2004
Musclecarfan88
184
Indianapolis, Indiana
Aug 8, 2004
  • Aug 8, 2004
mine is WAY out of balance and im sick of getting vibrated to hell. but i dont have the money for an alluminum one. so any body have an idea how much it will cost?
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Aug 8, 2004
  • Aug 8, 2004
You pay anywhere from $50-$75 where I'm from. And that's in Canadian funds, so that's about $6.38 US.
cjman15
Banned
Apr 15, 2004
1,009
Fairfield, PA
Aug 8, 2004
  • Aug 8, 2004
How do you balance a driveshaft? I need that done also.
Musclecarfan88
184
Aug 8, 2004
  • Aug 8, 2004
they spin it and what not and find a spot and then put wieghts on it, kinda like balancing a tire.
FrdMustangCpe
493
Sin City, NV
Aug 8, 2004
  • Aug 8, 2004
i need to do mine too, also what kinda shop would do it? tranny shop?
89MustangGX
I have nothing productive to add!
Jul 3, 2001
10,262
Mill Creek, WA
Aug 8, 2004
  • Aug 8, 2004
Are you sure it's the driveshaft -- I have yet to see one that actually goes out of balance (though I'm sure they do -- thus the reason for driveshaft shops).
If you're not sure and you want a cheap test -- get a hoseclamp big enough to go around the shaft and put it on -- see how it changes -- you can try turning it around so the spot where the worm gears are is in a different spot. If it imporves or feels the same but gets worse -- you're probably right. If you feel new vibrations or different vibrations, look elsewhere for your problems.
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Aug 8, 2004
  • Aug 8, 2004
May just need to replace a U-joint
HISSIN50
34
129
Aug 8, 2004
  • Aug 8, 2004
Ford tries to match components at the factory, but it is not a real precise balance.
i would call around and get price quotes. also note that the DS itself can be balanced (off the car) or it can be dynamically balanced on the car (so the entire rotating assembly back there is balanced).
you could also try removing the 4 12 point 12 mm bolts and turn the DS and reattach it - in case it was reinstalled out of phase at some point.
good luck.
oh yeah, GB, LMAO.
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
L
1996 harmonic balancer crank bolt. Help!
  • Lost in Palm Bay
  • Jul 21, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 24, 2026
Lost in Palm Bay
L
Foxbody high rpms and surging rpms
  • 86foxseth
  • Jun 9, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
  • Mindseye007
  • Aug 16, 2026
Mindseye007
