How much would you pay for an elctric fan working and tested in good shape from the junk yard. This dude wants 40 bucks for it.
?JerryDaugherty said:What are all the things I will need to run an electic fan? i dont want a controller, just a switch in the dash to turn it on and off. What kind of wiring do I need? Can someone make a complete list?
HISSIN50 said:Mike, Did you use the stock SN95 fan connector? Have you had issues with the high speed connector trying to melt? I am rewiring some stuff on the 94 and that is on my list (along with a circuit breaker on that high speed feed).![]()
Mike, thanks for the info.Grn92LX said:No, it didn't come with a harness. I used 10G wire I had in the garage and put connectors on it to slip on the fan harness. I only use the + and - terminals.
trents99 said:If you want to just straight wire it to a toggle then the fan has a ground wire and a power wire. Run the fan power wire to the toggle then the other side of the switch to a hot lead. The fan ground wire just ground somewhere. That's how mine is done, you just have to remember to turn it on and off every time. I'll be getting a DCC soon which is what I suggest for the long run.
If it was a 4th gen camaro, those fans are AWESOME! You can literally watch the needle come down when it kicks on. Otherwise it keeps temps right at the stat rating!The Fox said:I paid $10 for my fan from my friend with a camaro. It pushes/pulls some CFMs, I'm gonna just wire it up to be on with key. I'll have a strong alternator and battery so what can it hurt? And I don't have a/c, sound system or foglights robbing voltage so it should be ok?
Would anyone consider it halfass to have a fan on all the time? I really don't know if it's bad to have on all the time. Also, my fuel pump is hooked up to a switch and doesn't seem to shut off, is it supposed to. It's for a carb. It ticks pretty loud but when you start the car you can't hear it anymore due to big exhaust and lopey cam![]()
