  • SN95 4.6L Mustang Tech
How required are C/C plates?
  • Thread starter Thread starter FalconGuy016
  • Start date Start date Jan 1, 2006
F
FalconGuy016
437
Northern VA
Jan 1, 2006
  • Jan 1, 2006
I understand that C/C plates adjust castor and camber, but I really have no experience to tell me what exactly that would do for me. I am saving up for a Bilstein BTS kit (shocks and struts with some matched springs) and I was wondering how important C/C plates would actually be. I will eventually get them for sure, but would the in between time be bad or damaging in some way?
streetstang03
unModerator
Dec 27, 2003
the dark side of the moon/home of the 1999, 2003,
Jan 1, 2006
  • Jan 1, 2006
how big of a drop do those springs give??
if its more than 1.5", you're going to need C/C plates
timeless2
Vi Veri Veni Versum Vicus Vici
Admin Dude
202
154
the Shadow Gallery
Jan 1, 2006
  • Jan 1, 2006
Most say if you lower more than 1 inch or 1.5 inches, you will need them.
I am one for overkill and would have them installed if I did any kind of spring install.
While you are at it, grab a strut tower brace.
F
FalconGuy016
437
Northern VA
Jan 1, 2006
  • Jan 1, 2006
Got a strut tower brace
What exactly will the negative consequences be without C/C plates, I guess that's what I want to know.
D
d90212
253
kailua, hawaii
Jan 1, 2006
  • Jan 1, 2006
you butcher up your strut tower. elongate holes so you can attain the proper alignment angles. be sure to do a search on caster camber plates as well, like kmembers not all are made the same. Maximum Motorsport is one of the best brands out there.
F
FalconGuy016
437
Northern VA
Jan 1, 2006
  • Jan 1, 2006
^^ Yeah I plan on the MM C/C plates. So my strut tower will start... deforming I guess? Is this something that will happen immediately or do I have some time at least.
streetstang03
unModerator
Dec 27, 2003
Jan 1, 2006
  • Jan 1, 2006
your tires might wear unevenly. I would put the new springs and shock/struts on and let it settle for ~2 weeks. then, go get an alignment and see if you NEED C/C plates.
D
d90212
253
kailua, hawaii
Jan 1, 2006
  • Jan 1, 2006
it wont deform, but youll also make pple like me have a better day at shooting your alignment.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Jan 1, 2006
  • Jan 1, 2006
make sure that the steeda brace wont interfere with the MM plates. i know the MM brace doesnt interfere, but they were designed with teh MM plates in mind.
timeless2
Admin Dude
202
154
the Shadow Gallery
Jan 1, 2006
#10
  • Jan 1, 2006
  • #10
Lastly, make sure the person doing the alignment knows the car is lowered and knows what he/she is doing.
F
FalconGuy016
437
Northern VA
Jan 3, 2006
#11
  • Jan 3, 2006
  • #11
^^ Are there any keywords and points I can learn to see whether or not they are going to do it right? The last thing I want is to do all this and just have somebody else screw it all up.
StangPro
441
Roseville, MI
Jan 4, 2006
#12
  • Jan 4, 2006
  • #12
Tell them you want a print out showing it's in spec AFTER being torqued down, and watch them that the print out is the last thing that happens before they pull the heads off of the wheels.
hognutz
1,940
albany, oregon
Jan 4, 2006
#13
  • Jan 4, 2006
  • #13
with the bts system you should not need CC plates for the alinement.
MM uses sphericale bearings so it locates the strut more positively so it does not defect under load and change your alinements settings. They will transfer more road noise on very crappy roads though.
short story long one of the main reasons mustangs handle so bad stock is all the flex and deflection build into the system. I don't know how much of that is in the stock upper sturt mount though.
the bts system is designed for more optimum handling so it only puts the car down about 1" so you dont' lower your roll center too much. springs like the H&R supersports I went with will negativly affect your handling a bit by lower the roll center. I hated the 4x4 look bad enough I just did not care. I know MM still recomends thier CC plates even if not needed for alinement so I would call them and talk to one of their tech people. They offer them with thier starter box that includes the MM race springs that only have a 1" drop.
tomustang
Psychotic Member
3,434
McLean Hospital
Jan 4, 2006
#14
  • Jan 4, 2006
  • #14
that's some hard meat to swallow..
don't forget the "from the factory" misalignment, they aren't really in to spec, you can have stock suspension and have a hard time getting it into alignment
not much, the strut tower can withstand alot
trailblazr81
571
Hollister, Cali
Jan 4, 2006
#15
  • Jan 4, 2006
  • #15
I have heard of stock Mustangs having trouble being aligned. And stock you cant adjust caster. With Eibach Sportlines I was at -2.4 degrees camber. Front tires wore on the edges. Would be great if was a dedicated auto-X car but not best for street driving. I could see the tires leaning in on top. So I can really screw up caster and camber with the plates. You really should get them and have a shop do it or like me install and drive straight to alignment shop!!
mity2
I like Pro3 and all I got was this crappy CT.
Jul 24, 2003
2,872
StateCollege PA
Jan 4, 2006
#16
  • Jan 4, 2006
  • #16
generally, anything less then 1.5 requires no CC plate.
BUT i would use them for the adjastability it provide
reeber
574
26
38
Berlin, NJ
Jan 5, 2006
#17
  • Jan 5, 2006
  • #17
I am having mine installed tomorrow... I got the chrome MM plates... I am building my front in stages... I'll put the plates on, the get the control arm's / coil over kit.. Then finally do the K-member as I get the money together..
V_Eight
617
ATL
Jan 5, 2006
#18
  • Jan 5, 2006
  • #18
I have drag springs, that are about a 2" drop f/r, maybe more. I ate up the front tire in about 4-5k miles, just from camber.
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
2K
Fox 5.0 Mustang Tech Apr 11, 2026
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
J
PCV system help for S/C
  • jay99914
  • Feb 16, 2025
SN95 4.6L Mustang Tech Sep 26, 2026
AngryH58
A
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
