How should I fix this? (New Valve Covers) *DUW Pics*
  • Thread starter Thread starter breadfan35
  • Start date Start date Jan 25, 2004
First Prev 2 of 2
breadfan35
45
Dallas,Tx
Jan 25, 2004
#21
  • Jan 25, 2004
  • #21
astronut1885 said:
Breadfan, I have a question: Can you get at the hole in the driver's side VC? I want to know if it's even accessible, or if the upper intake blocks it off. Thanks.
It is not accessible for me. Perhaps if I didn't have AC and used something other than a breather, I might be able to. It also may be accessible with different Intakes. (I have TFS)
P
PRO50SC
1,012
Olney, Maryland
Jan 25, 2004
#22
  • Jan 25, 2004
  • #22
breadfan35 said:
He is referring to the EGR spacer. That won't work thought because then the EGR would be upside down and the holes would be on the other side of the TB. They don't go all the way through.
I thought that was what he was reffering to but I wanted to be sure before I made a reply.
astronut1885
1,899
Assonet, MA
Jan 25, 2004
#23
  • Jan 25, 2004
  • #23
So you put your oil in through the hole in the passenger side VC right? If you have a MAF system, I guess you're not supposed to have a breather on the VCs, because it lets more air in than is metered. I'll probably just put a cap on the driver's side and then put a breather with an attachment for the hose from the TB on the pass. side. That way I can just remove it to add oil, and still have the hose connected.
mustangdaren
605
Hildebran, North Carolina
Jan 25, 2004
#24
  • Jan 25, 2004
  • #24
Your Trick Flow intake runners must be a little shorter than the gt40. I didn't have any clearance issues with mine. It was tight though, about 1/8 inch clearance. I am getting ready to install a Bennett intake, hope it clears. If not I'll just modify the bracket like you guys did.
Asha'man
1,909
Denver
Jan 26, 2004
#25
  • Jan 26, 2004
  • #25
Who's Chad?
Ash
mike keirstead
1,121
ROLLING A JOINT
Jan 26, 2004
#26
  • Jan 26, 2004
  • #26
Get a hack saw and notch the bracket. Very easy. You could get another intake spacer too. I used a 3/8 and a 1 inch on my gt-40 for my tall covers. But if you don't want to do that just get a hack saw and start cutting.
The piece of the bracket that faces the passenger side where throttle cable go's through ( Just to the left of the cable) Cut that piece off and bend the bracket in towards the intake a little so it will clear.
Send those pics to m_keirstead@yahoo.com and I will do a little drawing for you if you have'nt already figured it out.
breadfan35
45
Dallas,Tx
Jan 26, 2004
#27
  • Jan 26, 2004
  • #27
Asha'man said:
Who's Chad?
Ash
Haha, I was waiting for someone to ask me that. That EGR was my friend Chad's EGR and he gave it to me. We wrote his name on it to not get it confused with the other ones we had.
breadfan35
45
Dallas,Tx
Jan 26, 2004
#28
  • Jan 26, 2004
  • #28
Send those pics to m_keirstead@yahoo.com and I will do a little drawing for you if you haven't already figured it out.
Well I took the piece to work today and had one of the guys that work in our Metal shop cut it for me and now it fits.
It is touching just barely so I'll be doing an little filing on it, but other than that it's fine. Thanks for all of the input guys, I appreciate it.
First Prev 2 of 2
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
  • dan50
  • Jul 18, 2026
dan50
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
New misfire after replacing valve seals/springs.
  • SpeedofDarkness
  • Aug 24, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 24, 2025
SpeedofDarkness
