  • SN95 4.6L Mustang Tech
How should i launch with the dr's
  • Thread starter Thread starter deftsound
  • Start date Start date Jun 14, 2008
deftsound
Please ask me how much my supercharger cost
Apr 6, 2004
945
Texas City TX
Jun 14, 2008
  • Jun 14, 2008
Well im going to try to hit the track sunday after i get my new bf dr's mounted (315/35/17) and am in need of some launch advice...
Should i be dumping the clutch or easing out of it, what rpm? I was thinking i would heat the tires up and just dump the clutch at about 5k...am i about on track?
BennyBlown2v
1,233
Carmel, INdiana
Jun 14, 2008
  • Jun 14, 2008
Easing it out is best. Radial tires don't wrinkle like a bias ply or slick, especially low profile 17" ones, so if you shock them they will just blow off, most of the time. 5k RPM is a good starting point. If you blow the tires off, simply back down to 4500-4800, if you bog, simply raise your revs towards redline Heat up the tires pretty well if the tires are brand new, and take your first pass kinda easy until you're sure the tires are fully burned in heh.
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
