According to Rick91gt, my compression ratio is going to be 9.03 to 1. This is not very boost friendly. Is there anything I can do to bring it down some? Thanks...PB
I checked it out but for some reason windows wont let me open the filevristang said:I have a file on my website that will let you look at the difference changing the headgasket thickness will make. I would post a link, but I can't get to the website from work. Look into the Math/Calculations section.
It will also allow you to make piston dish dome changes, and it provides some indication of how blowby/leakdown results will affect your CR.
Let me know what you think as far as user friendlyness, I am always looking to make improvements.
jason
Blk91stang said:The only was to do it is order new pistons. If you do it any other way, chances are your going to increase your chances of pinging even more with reduced quench inside the chamber. I don't understand how you think 9:1 compression is too high for 15psi? If you have any doubts, pull a little extra timing.
...and richen your fuel.Thanks for letting me know, I'll look into it. Let you know if I figure it out.pb_paulie_b said:I checked it out but for some reason windows wont let me open the file![]()
PoopDawg said:Port your water pump???![]()
.No problem J, let me know when you get it workin. I'd like to check it out...vristang said:Thanks for letting me know, I'll look into it. Let you know if I figure it out.
jason
