mr.p said:
Question along the same lines, my check engine light is on, but I am receiving no codes. There are other anomallys that are ocurring (bad idle, hard start, high TPS voltage, fuel pump runs constantly) that may all point to a common thing. Anyone seen any of these problems (the high TPS voltage, 4.25, and constant running fuel pump are my main concern)?
Thanks,
David
Bad or missing grounds...
Grounds are important to any electrical system, and especially to computers.
1.) The main power ground is from engine block to battery: it is the power ground for the starter & alternator.
2.) The secondary power ground is between the back of the intake manifold and the driver's side firewall. It is often missing or loose. It supplies ground for the A/C compressor clutch and other electrical accessories such as the gauges.
Any car that has a 3G alternator needs a 4 gauge ground wire running from the block to the chassis ground where the battery pigtail ground connects.
3.) The computer has its own dedicated power ground that comes off the ground pigtail on the battery ground wire. Due to it's proximity to the battery, it may become corroded by acid fumes from the battery.
4.) All the sensors have a common separate ground. This includes the TPS, ACT, EGE, BAP, & VSS. It is pin 46 on the computer
5.) The O2 sensor heaters have their own ground (HEGO ground) coming from the computer. This is different and separate from the O2 sensor ground.
6.) The TFI module has 2 grounds: one for the foil shield around the wires and another for the module itself.
7.) The computer takes the shield ground for the TFI module and runs it from pin 20 to the chassis near the computer.
8.) The computer's main power ground (the one that comes from the battery ground wire) uses pins 40 & 60 for all the things it controls internally.
If you have access to a digital voltmeter and would like help diagnosing grounds, make another post and I will try to help.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host)
