  • SN95 4.6L Mustang Tech
How to Correct Eibach Spring Sag Problem
  • Thread starter Thread starter mike2003GT
  • Start date Start date Feb 8, 2004
mike2003GT
31
Phoenix
Feb 8, 2004
  • Feb 8, 2004
Ok, so a few months ago I had the Eibach Pro Kit installed on my 03 GT. I was looking for about a 1.5" drop, and better handling. What I got was about a little less than 1" on the drop, and an expected stiffer ride. I also noticed that my car sags 1/4" on the drivers side. Now before everyone tells me that I need to lose weight , how can I correct this problem? Is there any way to correct the problem without replacing the springs? Any help is appreciated.
mike2003GT
31
Phoenix
Feb 8, 2004
  • Feb 8, 2004
anyone?
Modular2v
3,222
23
99
oklahoma
Feb 8, 2004
  • Feb 8, 2004
i installed the same kit on my stang and have no "sagging" problem what so ever... a pic would be helpful
stangman
2,690
10
69
in a 3 bed, 2 bath
Feb 8, 2004
  • Feb 8, 2004
did you use the stock rubber isolaters?????
mike2003GT
31
Phoenix
Feb 10, 2004
  • Feb 10, 2004
Nope, they replaced all the isolators (or at least I paid for them to be installed).
I
Isaac-1
824
SW Louisiana
Feb 10, 2004
  • Feb 10, 2004
It could be that one of the springs is rotated to the orientation.
ScortLX
261
Parker, Colorado
Feb 10, 2004
  • Feb 10, 2004
Mike....I have yet to figure out how to help a sagging problem. I have Steeda Sport springs on my '02 and the right rear sags about 1/4" and its driving me nuts. I added an extra isolator and it didn't help at all. Hopefully someone chimes in and can help both of us!
Nate
Modular2v
3,222
23
99
oklahoma
Feb 10, 2004
  • Feb 10, 2004
did you guys make sure the pigtails were facing the same way as the old springs?
K
Ken01GTvert
175
Colorado
Feb 11, 2004
  • Feb 11, 2004
If you want a lower drop then you can get rid of your spring isolators. In regards to one side being lower then the other I have the same problem except the difference is about 1/2 ". I've got Pro-kit springs as well. Maybe we need to add a 150lbs of weight in the passenger side to even things out.
XStanger
383
#10
  • Feb 11, 2004
  • #10
I have the same problem! I thought it was because the springs settled and I never have a passenger.
350HPZ
68
#11
  • Feb 11, 2004
  • #11
Try spring spacers steeda sells them each spacer raises the height .25inches.
01GT eibach
1,075
Pittsburgh, PA
Feb 11, 2004
#12
  • Feb 11, 2004
  • #12
The rear height can get evened out with adj LCA's, and the stock LCA's should be changed out anyway.
mike2003GT
31
Phoenix
Feb 11, 2004
#13
  • Feb 11, 2004
  • #13
You know, funny thing is, I heard about this prior to having the springs installed, but I've had good luck with Eibach's in the past. As for the orientation of the pigtails, I'm not sure- I had them installed at www.bieberfever.com in Phoenix. So if I install adjustable lower control arms I can compensate for the sag. Would it be worth just getting rid of the Pro Kit and going with something else?
skrow03GT
47
Allen, TX
Feb 11, 2004
#14
  • Feb 11, 2004
  • #14
The problem is the pigtails are not facing the right direction on the spring. If i remember correctly, the all should be facing the middle of the car. If they arent lined up you end up with some of the springs being a tad bit longer than others, causing your sagging problem. Dont bandaid the problem with adj. LCAs, just fix it. If it was done at a shop, I would bring it back to them, because the installation instructions supplied with the springs clearly states how to align the pigtails.
Modular2v
3,222
23
99
oklahoma
Feb 11, 2004
#15
  • Feb 11, 2004
  • #15
the pigtails of the springs should be facing the same exact way the old ones did! I did the install myself and i dont have any sagging problems
mike2003GT
31
Phoenix
Feb 12, 2004
#16
  • Feb 12, 2004
  • #16
Allright fellas, it's going back to the shop tomorrow for a "pigtail" check. Hopefully it will solve the problem. Hey thanks for all the help here!!
N
NewbStang
213
#17
  • Feb 12, 2004
  • #17
let us know how it tturns out
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
Free VE Table Corrections — Drop Your MSQ and a Datalog, I'll Do the Rest
  • X-cam34
  • Apr 12, 2026
  • Digital Self-tuning Forum
  • 2 3
2K
Digital Self-tuning Forum Aug 26, 2026
X-cam34
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
T
What's it Worth? 2002 GT conv/auto
  • tonydetesta
  • Jan 7, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Jan 21, 2026
Mustang5L5
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
