If you're going to be taking the PS and AC off the car, I can only help you with the AC part. You'll need some AC line disconectors, basically the same thing as the fuel line disconectors. You'll have to take two (I think) off of the AC condensor, and there will be two more on the pass side of the firewall. Where thoes lines meet up at the AC compressor, there will be a 10mm bolt that holds them in place, take that bolt out and the lines will come out. Then theres 3 or 4 bolts holding the compressor onto the bracket. Finally, take the radiator brackets off and pull that out enough so you can slide the AC condensor between the radiator and the front support.
