how to fix a tiny hole in my rim?
notch88
18
hey everyone, i have some aluminum centerline racing wheels and one of my front skinnies seems to just loose air over time not necessarily go flat but loose air and i took it to the shop to have the hole fixed and it turned out there is a really tiny hole in the back side of my rim...whats a good,safe, and durable way to fix this....some one told me jb weld would work great but i was just wanting some advice...
thanks,
Tyler
my daughters prelude walmarts told her it was a cracked wheel 17's alum, they wouldnt touch it sooo, she dont drive over 140 mph i put fix a flat in it and havent had a leak in 3 months so far good luck.
Why, did your daughter frequently top 140 mph before then?
Chances are you have a leak in the tire, not a rim problem. Spray it with soapy water and look to see if it bubbles up anywhere, which would be the escaping air. Spray the valve stem and around the bead, theyre known culprits.
welding is definitley the go. I have seen plenty of rims weld repaired.. I have had a rim completely split in half repaired. Did end up with a crap load of counter balance weights on it however
If is just a pinhole from manufacture, just plug it with superglue, JB Weld, or similar stuff. Some two part epoxy would be be my choice. I have sealed aluminum manifold water passage leaks with some of this stuff, gas tank repair, I believe. You could just try some RTV, or RTV windshield sealer. It will go into tiny spaces if you let gravity work for a while. If you go from the inside, it will typically be pushed outward in operation, and should work fine.
Obviously, welding is good also.
thanks guys...i think im just going to go the easy way and just dab a pinch of jb weld on it and let it sit overnight that away i wont have to take the tire off either....
thanks,
Tyler
