how to fix driver side floor pan
Jaswir
578
Orlando, FL
ok my driver side floor pan is pretty bad... the back left side where it bolts to the floor is gone... the seat goes threw the hole... i have about a 2x2 inch hole plus its kinda weak around it... i will get pics if you guys need it... is there anyway to fix it for a body shop to do it? or do i need to buy a floor pan and have it welded in?? because of this it also has broken my seat braket due to it sitting on a 2x4 so i don't have that gansta lean... just wondering on how much it cost to fix? what have you guys done? how much has it run for a shop to fix it for you??
Go to your local boneyard with some snips and a good 18v cutter. Take a large section of GOOD floorboard from a Mustang and do some surgery on your own. That would be the cheapest way....if you have access to a welder and can weld.
Mine was fairly beat up, a long rip in the metal and some holes, I cut them out and filled them with sheet metal from a fender. I just cut out the cancer and replaced it. If you grind the welds down and use some undercoating, you will never even see the fixed damage.
