How To Get Halo Lights Always Running
zapper375
I recently bought and installed Raxiom Black Projector Headlights - Dual LED Halo and they look amazing! Only thing is i want to be able to make the LEDs and halos always on when my car is on, without just setting the parking lights on. Anyone know a solution to his?
Isolate the power and ground wires for your new light kit.
Isolate a power and ground at the fuse box where power is on only when ignition switch is on.
Purchase a 30 amp relay from the autoparts store and follow the diagram that accompanies the relay.
This whole thing would be best soldered in but don't worry too much about it if you can't solder. You can use weather proof t-connectors.
The idea here is you will wire the relay so that it's 'closed' when the ignition switch is in the 'On' running position. You would install this inside of the loop for your headlight switch.
