How to Install a Spool?
If I were to have a spool and a rear end... What all would I need to install it? I have new axles, c clip elims and new gears and I am getting ready to install, and I don't know if I need the rebuild pack and the spool bearings, or just the bearings?
you wont need a clutch rebuild kit since you wont have a clutch in there anymore(limited slip is gone). i'm not sure what you mean by spool bearings, maybe you mean the carrier bearings? if so they should be replaced just because. same goes for the pinion bearings, but if you're not doing a gear swap i'd leave the pinion alone unless it makes some funny noises. If you find a good write-up on revuilding one of these suckers PLEASE PM it to me, i'm rebuilding my trac loc and all bearings tomorrow and hope i can do it right this time, good luck it shouldent be too hard, and save all your old parts just in case!
~Mark~
