  • 2005 - 2009 Specific Tech
How to launch a mustang?
  • Thread starter Thread starter oatmealr
  • Start date Start date Oct 20, 2004
O
oatmealr
27
  • Oct 20, 2004
I am going to get my mustang this week most likely, and it will be a huge change for me. I have been practicing a stick on my girlfriends '95 neon, and I currently drive an auto VW Golf... so this is a huge change for me.
How do you properly get a V8 monster to launch properly? I can change gears pretty easily after 1st, but I think everyone knows 1st gear is the trickiest to master. Just go through the steps for me, if you could?
34
  • Oct 20, 2004
Sorry, I couldn't help myself. Its simple, wind up to desired RPM and drop the clutch. I did it at about 3K last night on my drive in the GT and it worked great
peyotesands
119
Las Vegas, NV
Oct 20, 2004
  • Oct 20, 2004
17 x 10 deep dish Bullets with Slicks should do it.
Man, you're going to have fun if you're moving from a douche bag car like a VW to a 05 Mustang GT. And a 5 speed no less. Rock on!
O
oatmealr
27
  • Oct 20, 2004
Yeah, but I was hoping for a bit more description. How slow do you pull out the clutch when trying to get a good start? If I'm on a slight incline and my foot is on the clutch to 'drop it' am I holding up the hand brake so I don't roll back? Or am I letting it slip ever so slightly and then pulling out?
I'm a newb when it comes to sticks, I'll be honest.
peyotesands
119
Las Vegas, NV
Oct 20, 2004
  • Oct 20, 2004
Honestly depends on the clutch. My 98 GT is really short. I can't speak for the 05. Mine engages as soon as i let up on the pedal. one foot comes up and the other foot goes down. Remember there's a ton of torque behind the 05 engine. it won't take much to make a smooth launch at a low rpm. start off keeping it below 2k during launch until you get comfortable. There's bound to be a world of difference between a neon and 05 GT as well.
I still like the other dude's suggestion of revving it to 3k and dumping the clutch. You'll probably figure it out a lot quicker that way.
VOORHEES
Stangnet's "35th Limited Edition" VIN Guy
3,046
36
119
LaGrange, GA
Oct 20, 2004
  • Oct 20, 2004
I went from a four cylinder clutch to a V8 clutch when I bought my 94 GT in 1996. I was used to a clutch, so the difference was easy to adjust to. Just don't use the e-brake on hills. Practice more and about a week you'll have it.
-Jason
peyotesands
119
Las Vegas, NV
Oct 20, 2004
  • Oct 20, 2004
-Jason
if he's that concerned he should take it to an empty parking lot and practice.
stangmi
12
  • Oct 20, 2004
for a gentle start.
1. floor the clutch
2. rev the engine rpm to 1000-2000
3. release clutch slowlly
4. when the clutch reach the G-point, hold it there for a second or so until the clutch fully egages.
5. AFTER the clutch fully engages, step on the gas to accelerate to a proper rpm for 2nd gear.
the G spot is very important when handling a stick. You can try to feel it with this practice.
park the car in a parking lot, keep your right foot off the gas,
now, release the clutch VERY slowlly, feel carefully at which point the car starts to move. repeat this practice until you memorize where the G spot of you car is.
dont rev your engine too high or hold it there too long at G spot though, this can burn your clutch. because this when the clutch plates are grinding.
FallenPhoenix
911
Odessa Tx
Oct 20, 2004
  • Oct 20, 2004
it's going to have to be mostly by feel, we can tell you the basics but once you do it a few times you'll get the hang of it
Ernad
celibate sans pants
Apr 2, 2004
Grand Rapids, MI
Oct 20, 2004
#10
  • Oct 20, 2004
  • #10
Like said, just get to a praking lot and practice.
As far as the hill thing goes: There are two ways to start going uphill without, or a minimum, backdrop.
One, your car is in gear, your L foot on the clutch, your R foot on the brake. Quickly, your R foot moves to the gas pedal, giving an x amount of gas, while your left foot lets out the clutch enough so that you have a smooth start without back drop. This needs some practice, to find the right amount of gas + right amount of clutch use.
Two, you use your e-brake. You pull your e-brake up. Put your car in gear. Give it some gas and stay on it, say 1500-2000 rpm, and let out the clutch to the point where the car would start to move. Then, you slowly lower your e-brake and your car starts to go forward.
Using the e-brake the right way, you will not be going down, however, I don't recommend it unless you have to. Once you get used to the car you'll be able to start uphill with minimum backdrop.
Sainted
33
#11
  • Oct 20, 2004
  • #11
The new stang has the brake and gas properly positened so you can give it gas whith out taking your foot off the brake i.e. heal toe. I like to use my toe for the brake and heal for the gas but some do it the other way. Don't use the e-brake. And like the previous poster said go to a parking lot (empty) and with out giving it any gas slowly let out the clutch till you feel it start to grab and get use to that distance from the floor.
I
iviustang50h
50
Wisconsin
Oct 21, 2004
#12
  • Oct 21, 2004
  • #12
Do exactly what Stangmi said above for starting at lights and such. Once you get used to starting with no problems then start at 2000rpm and let off the clutch completely while mashing down the gas. Determine if that was too much wheel spin or if the car bogged. If it was too much wheel spin try smoothly applying the gas once you disengage the cluth. Once you practice you will find the best rpm and the best way to apply the gas (slamming it down or smoothly applying). Good luck and have fun!
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
9
Will I feel a difference
  • 90Stanger302
  • Mar 12, 2026
1965 - 1973 Classic Mustangs -General/Talk- Apr 13, 2026
Suspension Setting Front Alignment - Do I care about the rear's thrust angle?
  • dan50
  • Nov 27, 2025
Fox 5.0 Mustang Tech Nov 28, 2025
Kid wita 5oh
R
Progress Thread A small update on our first-gen Mustang project
  • Restomotive
  • Apr 24, 2026
1965 - 1973 Classic Mustangs -General/Talk- Apr 24, 2026
Restomotive
R
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
