- Feb 25, 2011
- 9
- 0
- 2
ok I have a 94 vert I got thru trade it had been switched to carb by the previous owner but was a hack job. I have went thru and cleaned it up and installed a duraspark style ignition on the car. the factory 42 pin plug is still in the engine bay but the engine harness has been removed but I wired it up so my factory tach and oil psi and water temp gauge would work. my problem here is the fuel pump will cycle with key on but will not run how do I make it run when the car is running I had a family member convert a 89 vert to carb and he ran a signal wire from the coil to the control module plug to make the fuel pump act like it should my question is have any of you ran into this and fixed it if so how? I do not want to run a toggle switch would like to keep it all in wiring.
