Paint and Body How to paint tail light assembly textured plastic
AnthonyA1234
5 Year Member
Aug 17, 2020
674
111
63
Florida
I’m changing the lens on my tail lights and I wanted to shoot some fresh paint on the assembly while I’m doing this. The assembly has a rough texture to it. I wanted to use this sem trim black paint I have laying around. How should I prep this to spray some fresh paint on it?
I did semi-gloss white on mine when I repainted them and put new lenses on. I really like how they look with the lights on. I think you could do a semi-gloss silver and it may even look better.
Reactions: General karthief
I always like to start with a " grease and wax" remover, if not lacquer thinner or Acetone... I like to make sure I am not scratching any contaminants into the paint, metal or plastic....
Knew a person who's father had a model A sanded down to bare metal and knew he was not going to get to it for at least a year... He sprayed and wiped it down with WD40, to prevent any rusting..... Wiped it down later with every chemical known to man, even finally had the body dipped... The primer/paint would still fish eye on him.. I think they gave up on it and had it crushed......
Just saying....
  • Wow
Reactions: 89ripper
Sooo many things can cause fisheye in paint, first of all you don't wait a year to cover bare metal, and you don't use petroleum based anything to coat bare metal before primer/paint, more So with WD40, it's formulated to penetrate metal surfaces.
We know better now. Back then mah...
