mytight95 Active Member Apr 11, 2003 2,605 0 46 Dothan,Al Mar 28, 2006 #1 Mar 28, 2006 #1 I keep having an intermittent light from the abs system, and want to figure out why it is doing that... So can i use my engine scanner on it.... same principle right? Or do i have to use another method. jason
HISSIN50 "How long does it take to get help in here? 15 Year Member Nov 29, 1999 31,179 34 129 Mar 28, 2006 #2 Mar 28, 2006 #2 Jason, take a look in here. Good luck.
mytight95 Active Member Apr 11, 2003 2,605 0 46 Dothan,Al Mar 28, 2006 #3 Mar 28, 2006 #3 thanks ...... "good luck" is this stuff that bad to trace down and fix. jason
HISSIN50 "How long does it take to get help in here? 15 Year Member Nov 29, 1999 31,179 34 129 Mar 28, 2006 #4 Mar 28, 2006 #4 mytight95 said: thanks ...... "good luck" is this stuff that bad to trace down and fix. jason Click to expand... It can be a real PITA or go real easy. I often say good luck at the end of my posts - it wasnt in regard to tracking down the issues. But since it might be a PITA, good luck.
