Hey guys, I need to take off my font bumper, I tried it one time but wasnt sure what clips or bolts to take out. How do you get it off?
Mr. Rustypwnz
Advanced Member
the fender will hold it on by 3-4 11mm nuts, and one 10mm, a side.
the front will be 2 5/16 ( in front of rad)
under the front of the bumper it should be 5/16's as well.. although i forget how many there are..
ok thanks, there are some plastic pieces on top of the grill that look like rivets or clips, do those need to come out?
BK_CAULEY
it's built for speed not longevity, woman
no leave those attached to the header panel. the 5/16's hold the header panel to the core support.
Cobra912
To install the intercooler.
Also do I need to take out the corner body pieces in between fender and headlight?
Cobra912
I havent gotten it yet but I am going to order it in a couple days. I am going to use an ebay intercooler, once I get that mounted ill be able to see exactly what bend pipes I need for the cold side.
FWIW, you can't beat the value and efficiency of the VS Racing coolers for the $$$$. My buddies car is making close to 1000rwhp through their big one and I used to have one as well, worked great. Lot better quality then my first Ebay cooler.
Good luck!! Taking the front bumper cover off is simple. You don't have to remove anything but bolts to remove it. Just unplug your headlights and then take out the nuts from the studs where the fenders/bumper cover meet. Then the two up top near the hood latch then the ones on the bottom near the black air damn piece.
ok awesome thanks for the info guys. I know VS racing makes quality stuff but I dont plan on making anywhere near that amount of HP and I am on a serious budget.
Matt123456789
- Mar 28, 2016
- 1
- 0
- 1
Hi, I am also trying to remove the bolts in the fender that are connected to the studs in the bumper and I think i broke the studs but they will not pull out so the fender and bumper are still attached to the car. Any thoughts on how to get them separated so I can remove the fender and bumper off the car?
Thanks
Thanks
It's very common for the studs to spin in the header panel. It's not fun, but I had to spread the cover away from the fender and get a pair of vice grips on them. When you get them out, clean all the threads and put some anti seize on them, then jb weld them back into the header panel before you reinstall the cover.
EDIT: To be clear, hold the studs with the vice grips while you turn the nuts off. Once the header panel and bumper are off you can remove the studs to clean them up and reinstall.
- Replies
- 1
- Views
- 142
- Replies
- 10
- Views
- 400
- Replies
- 1
- Views
- 242
Electrical
Headlight Harness Route
- Replies
- 0
- Views
- 110
