How-To Remove Front Speaker
AndyG47
Jersey
ORIGINALLY FROM V6TECH FORUM. My friend Zincyellow suggested I post this here so I shall. I am working with a 2002 coupe here so anybody with a 99-04 should find this helpful.
Done this alot myself.
1. Open the door obviously
2. Remove the pop 'em bolt on the bottom front corner
3. There is a small tab above the switch bezel press down on it (not much force required) with either your fingers (recommended) or a flathead screwdriver and pry outward then pull up on the whole thing and it will pop off.
4. Take the two screws off the switch bezel on the underside
5. Then these two on the door.
6. Then get a grip on the door and pull up and out (watch for the door handle)
7. The speaker itself is being held by 4 screws.
Re-installation is reverse with a few things.....
The door has a lot of hooks on the back make sure they all go to their proper holes and work with the door unlocked so you can put the lock pin in the little hole in the top of the door.
NOTE:The factory 5x7 speaker can be replaced with an aftermarket 6x8, it will fit.
