  • 1994 - 1995 Specific Tech
How to remove these vacuum lines?
  • Thread starter Thread starter DarkProphet
  • Start date Start date Aug 21, 2005
DarkProphet
391
Quakertown, PA
Aug 21, 2005
  • Aug 21, 2005
While doing the rest of my engine work, i noticed that the vacuum lines for the EGR and smog pump all come from one harness of lines. Does anyone know where these all come from? id like to remove them at the source, because i wont be needing any of them.
RIO5.0
6,892
N.H.
Aug 21, 2005
  • Aug 21, 2005
If your speaking of the Red/Grn/Wht plastic lines then they all un-plug at that rubber "tri" connector....just plug the ends good and send it into the pass side fender...the soleniods they connect to are in the fender...if you remove the inner fender line you can access them...
Here's the EGR/smog pile...
DarkProphet
391
Quakertown, PA
Aug 21, 2005
  • Aug 21, 2005
Do you have to put bolts back in place of where the smog line connects behind the engine?
G
Green 94 5.0
2,601
12
79
Ft. Lauderdale, FL
Aug 21, 2005
  • Aug 21, 2005
yes. those lines feed directly into the cylinder heads. if you remove that line completely, they need to be capped.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Aug 21, 2005
  • Aug 21, 2005
Yeah, a 9/16NC short bolt w/ some thread sealer will do the trick. Or if you can find a plug that size....either way.
Scott
CManT1914
3,172
Killeen, Texas
Aug 21, 2005
  • Aug 21, 2005
Ford and summit sell plugs for this very purpose. They're called thermactor plugs, and summit has them for like $3 or something. Ford is a little more, but you don't have to pay shipping.
RIO5.0
6,892
N.H.
Aug 21, 2005
  • Aug 21, 2005
What he said...some people opt to cut the ends off crossover and crimp em then just re-bolt em on...I have read that sparkplugs will also screw right in?? to plug the hole...
I made block off plates outta 1/4" Alum and a gasket and bolted em in...
I seem to remember that crossover tube being a PITA to remove with the motor in place.
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
Smog delete /vacuum lines
  • Serg.Xof
  • Feb 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 18, 2026
RileyDymond
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
Vacuum line question?
  • Mustang Momma
  • Feb 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 3, 2026
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
