How to replace oil pump?
BYRDPE
1,556
Memphis,Tn.
Oil pressure went to zero on the mechanical gauge AND the stocker. Didn't hear any chatter as I immediately shut her down. I removed the oil pressure sending unit and had the wifey crank her over and not a drop spurted out.
Next, I remove the dizzy and checked the shaft. It looked ok, so I took a long screwdriver and nudged it to see if it was broke and I noticed it was very loose. Thinking it was broken I used a magnet to try to remove the shaft, and the magnet picked it up, but I couldn't pull it out the top, as it seemed like a washer or clip, was stopping it from coming out. Next thing you know...blip.. now I don't see it any more. :nonono:
Don't know if it fell all they way through to the pan or not, but I do know its not where it should be. I guess its irrevelant anyway as the pump apparently stopped working.
Anyway what's involved in removing the oil pan to access the pump? Any tips from those who have done this will be appreciated.
I do have a Haynes manual but it doesn't really go into details on how to actually install the pump.
Thanks for the help.
BTW... sorry for the long post. I just installed my H/C/I combo and I'm a little down in the mouth. :(
I hate to tell you but it problably fell in the pan they usually do. That clip is designed not to let that happen so remember to reuse it just set the height right. Did you try to spin the oil pump with a primer to check it? I would problably just yank the motor out this will give you the best access to what you need to do and it takes no longer. Then you can replace the timing cover and water pump gaskets that also go bad along with a new rear seal. Just use a stock replacement M68 pump and get a new shaft. With your new top end installed just do it right the first time get it sealed up good and you will be able to enjoy your car for more years to come and you wont have to worry about (horsepower leaking onto your driveway)
Definitely sounds like you turned the pump shaft into a twizzler :( that clip usually makes the shaft stay put in the pump unless the shaft is in 2 pieces (or if the clip broke of course). If pulling the motor is out of the question at the moment this is a pretty easy job to do in the car. You can unbolt both motor mounts/trans mount and jack the motor up as high as you can to drop the pan but it still won't come out all the way because of the crossmember underneath it but you can easily tip it enough to work inside it. I totally agree its almost worth pulling the motor just to get at it easy and maybe take care of some other things like Punisher said but if that isn't an option I've replaced quite a few in the driveway in a few hours :)
I dunno, my vote would be to leave the engine in the car, unbolt the motor mounts from the frame, and jack up the motor. You won't get the pan out like Fox8950 said, but I changed my pump once in the manner he described, it wasn't that bad. If your engine really does need some other work, then yeah I would yank it, but if it really doesn't, then I would only fix what is wrong.
Actually I just completed a H/C/I install plus new clutch on 9-30-07 so the oil pump is the only issue at this point. I guess I could try it in the car and if I run into trouble I can always go the extra steps and pull the engine.
Hmmm....
Been there, done that - You can do it in the car, but it is hard to do. The best way is to pull the engine.
Disconnect the battery at the battery ground terminal, remove the fan and fan shroud. Both motor mounts will need to have the large nuts that secure them to the frame removed. The trans mount will also have to be loosened, and it is a good idea to remove the drive shaft.
I also had to disconnect the cat pipes at the headers to get the engine high enough to remove the oil pan. Be prepared to have to drop the steering rack and disconnect the steering shaft. Jack up the engine with a wood block under the oil pan and watch for things that bind or hoses/electrical wiring that may need to be disconnected. I put a couple of wood blocks between the headers and the frame to support the engine. You will likely need to jack up the rear of the transmission as well to get the required clearance.
Scrape the pan mating surfaces clean as possible - old gasket stuck to the surfaces are a source of leaks.
Get a high volume/heavy duty pump, and a replacement HD pump shaft. FMS makes one, and ARP does too. When you install the pump, the funny looking washer thingy goes on the part of the shaft that fits into the hex socket in the distributor shaft. It keeps the shaft in place when you remove the distributor, which you will have to do to prime the pump. Forget to put it on, and the pump shaft can come loose and fall down in the bottom of the oil pan.
There is a one piece oil pan gasket which will help re-assembly if you can find it. If you can't get this gasket, use weather strip adhesive to secure the cork gasket to the pan rails and the rubber strips to the bearing caps. Use lots of Acetone or MEK to clean the gasket surfaces so the weather strip adhesive will stick good. Read the instructions on the adhesive carefully to make sure the gaskets are permanently stuck in place and won't move when you slide the pan in place. Use lots of blue silicone sealer on top of the front and rear rubber seals where they mate with the pan.
Fill with oil, replace the filter. Reconnect the battery, switch the ignition on to enable the gages, but DON'T crank the car. Remove the distributor and use a 1/4" hex socket to turn the pump counter clock wise (same direction as distributor rotation) until you see oil pressure (an external gage is a great help long about now). And keep turning for about 30 sec after you see the pressure come up. A reversible drill is the best tool to use to turn the 1/4" socket. The pressure should come up to about 50-80psi with cold oil. Once you see good pressure, check for obvious leaks, and then and only then, lower everything back into place and bolt down the mounts and anything else you had to take loose.
Re-install the distributor and set the timing with the engine running using timing light (don't forget to disconnect the SPOUT plug and reconnect it when finished) 12-14 degrees BDC is good. Start up and check for leaks, let it warm up and look again for leaks. It took me 2 days plus, but I am old and slow, maybe your granny is faster.
This is the part thats not really clear to me. Maybe I'll understand more when I get my pump and shaft in a few days.
Are you saying the washer thingy goes toward the dizzy to keep the shaft from bottoming out in the dizzy? If so, is there anything that secures the shaft in the pump? I figured the washer would go in the pump to secure the shaft. :shrug:
Thanks for the "how to"...it is very helpful. :nice:
the "washer thingy" is supposed to go on the shaft, up near the distributor. It is designed to go all the way up just under the block's casting right under the camshaft there, where the shaft goes into the little hole in the block. Basically, if you pull out the distributor, and the shaft is stuck in it, the "washer thingy" hits the casting and prevents the distributor from taking the shaft with it. Basically, put the washer thingy about midway on the shaft, put the shaft up through the hole, then into the oil pump. Then push the washer thingy upward on the shaft till you hit the block, then back it off a smidge so it's not rubbing on the block when it's turning.
Got it.....great description.
Much appreciated! :nice:
I really reccommend yanking the motor and taking a glance at the health of your bottom end. I snapped a shaft when the pump locked up, I pulled the motor for a check and was very surprised when I saw the bearings. Considering it never knocked or anything, the top end just clacked a little from lack of oil. I shut it off pretty fast also.
Thanks for the tip. The shaft looked ok...I just think the pump probably got clogged from some of the debris during the H/C/I install.
Not really worried about the bottom end either. If I have bottom end issues after I replace the pump I'm going with a 306 or 331 short block.
