How to spend 800.00 on 99 gt
gears w/auburn diff.
70mm tb
ta
o/r x pipe w/flowmaster muff.
c&l 80mm mass air
dragon plenum soon to come
shifter
nitto drag radials
lowered w/eibach pro kit
would control arms and sub frame connectors help or would a new clutch and aluminum flywheel do more.
Sell the stang and put that mustang down for a 02 WS6. J/K lol
Personally i would take that money and beef up your rear end. I would get a 31 spline in there. A lot of the guys on this site just focus on there motor and forget about there rear end. If you don't want to do that then just drop the car. Your handing and 60 ft will inprove at the track.
99redgt said:
I have all the bolt ons would pnp heads and cams do a whole lot or should I just do cams I am sure you guys have some good ideas.
Well, if you are having traction problems then some new control arms would help.
Subframes "can be" a cheap mod. It definetly tightens your car up, but if it just a daily driver you might not really notice much.
Cams would definetly make a power difference (10-15hp), but $800 is not enough for both cams and p&p. I think you would get more out of cams then a p&p job.
How about longtubes? The will give you a solid power increase of about 10 hp.
If you do the work youself, a set of cams and longtubes would really boost the power of your car for $800.
