How to tap a hole!?
DFG 5OH
1,341
Louisville, KY
Am I retarded or something? I cant figure out how to take a hole into my upper intake to plug a vac. line. Heres a pic of what i'm trying to do:
i've got the kit thing, with the taps and stuff. I tried spinning one down into the hole but i think i stripped the tap, is the metal that strong? What was I doing wrong?
You might have been using the wrong diamter tap. You don't want to tap it all the way the first pass on aluminum. It will just clog the crap out of your tap and probably render it useless. I know with grinding, aluminum destroy carbide bits by clogging them up. Maybe someone who knows better than I will chime in. mo_dingo is probably the expert on tapping/dying (and extracting bolts and busted taps from experience) ;).
But you know what we did was just use all of those holes for my vacuum lines. If you don't have the press-fit tubes that came off the intake then I guess you're SOL unless you find a fitting (or plug it of course).
Make sure that the thread count and pitch is the same for the bolt you are using. The tap has to be really straight and only go 1/4 to half turn, then slowly back it out...then another 1/4 to half and back it out...That will work the best...or find a bolt thats close and JB weld that ****e in there!
I was lucky to just find the right bolt that threaded into that hole...something along the lines of a self-tapping bolt will help....
Take a Coke can...cut a 3/4-1" square out of it....trim it round to fit over that opening...leave a some around the edges to cover the hole...sand the paint off the area around the hole...mix up some JB weld...apply that to the patch...slap it over the hole and your done...That stuff is the balls...let it dry o/nite...put some Silver paint on it...Thats one sealed hole thats not gonna leak..
for that matter use that Alum tape and JB over that...I used the same thing to modify my tall VCs...that was last year and its still rock solid and leakfree..
sometimes you gotta improvise...or ghetto rig something.... :D
This is the proper way to tap a hole. First, determine what size the hole is already. Measure with a dial caliper or micrometer. Or just use your tape measure, and take a guess.
When tapping a fresh hole, you need to drill it to the proper size. Now, each tap size has a specific drill bit size associated with it. Like a 5/16-18 tap needs a "F" drill bit. I don't remember the numerical equivalent to that letter drill bit.
So, if you can't get an accurate measurment for whatever reason, get a drill bit set out, and find a bit that will barely go in the hole, nice and snug. Now you know that the drill bit for the tap has to be bigger than that drill bit.
So, once you find a tap and drill bit that will work, lay the intake upside down, so the hole is perfectly straight up. Make some wedges, duct tape it in place, whatever will keep it perfectly still.
So, once you have the right tap, drill bit, and the intake is rock solid and the hole is pointing perfectly straight up, drill the hole down about 1" or so. If you can drill all the way through, that is preferable, as then you can tap it all the way through. If you chose the bit size right, it will take only a little bit of metal away on all sides. Make sure you are perfectly aligned with the hole. Having someone watch you drill is helpful also to keep it straight.
So you have your hole drilled, now take your tap, get a cup full of motor oil, a bunch of rags, and a metal pick tool that is perfectly straight. Get your tap, put the tap in the tap handle (they make T-handles specifically for taps, get one that will fit this size, it helps a lot)
Now dip the tap in the oil and stick it the hole. The tap is tapered, so it will go in a little bit, then stop. Make sure the tap is perfectly aligned, and make a 1/2 turn, putting firm, but not hard pressure on the tap. You should feel some resistance while turning, and this is normal, as you are cutting out the aluminum.
Now back the tap out until it's loose, and remove it. Clean all of the metal filings and oil off with a rag. Take your metal pick tool, dip it in oil, and stick it in the hole and move it around. The metal will stick to the oil, and that will clean the hole out. The prevents problems, like stuck taps or crappy threads.
Then dip the tap into the oil, and put it back in the hole. Now, turn it the 1/2 turn you already did, and then do another 1/2 turn. Then back out the tap, clean it off, clean the hole, and repeat this until you tap the entire hole.
If at any point it feels like there is more than normal resistance, back the tap up immediately, clean the threads, and try it again. If you keep getting to the same point where there is too much resistance, you need to try cleaning out the threads more, or making sure your tap is going in straight. If it still has too much resistance, and you have enough threads, just stop there. No reason to risk breaking the tap.
If the tap binds, and you turn to hard, the tap will snap, and you will have a 5 dollar tap stuck in a $400 intake.
But as long as you take your time, and only go an additional 1/2 turn each time, you will do fine. The tap will spin freely when you are in already tapped threads, so you will feel when you get to fresh untapped metal. I learned this the hard way, so please heed my words, as I only speak from experience. And getting a broken tap out is not easy.
Then when you are done, find a bolt to fit it, slowly thread it in to test it. The bolt should go in like butter. Aluminum is extremely soft, and very easy to strip.
So you shouldn't have to put a wrench too it until it's flush with the intake. You don't need to tighten it much either. Maybe 10 ft-lbs at the most. So once you know the bolt goes in smoothly, put some thread sealer on the bolt, and stick her in.....
But you have the right idea to plug that hole. Best thing to do in that situation.
Scott
surely someone is gonna make a comment about "tapping a hole"...no?
For real though, mo dingo gave the best answer i've ever seen in regards to it!
