how to tell bad cats?
bad cats? they piss and **** on everything in the house, claw up the chai....oh those cats :P
Not sure...mine have never given me a problem. They work well as wheel chauks :D
with any exhaust restriction one can set up a vac gauge. rev up to a given RPM (say 3K). hold it super steady and watch the gauge. if the vac begins to drop, that suggests an exhaust restriction. diagnose the system from there.
good luck.
I had a clogged cat eons ago when I still had the stock H-pipe on the car. The car bucked like I was learning to drive a stick shift all over again. It did this while driving and it took about 2 minutes for the car to get up to 40 MPH (and no, I wasn't flooring it).
You'll know it if the converter is clogged. The car will be slower than a lawnmower.
Joe
If the temp is the same, incoming and exiting, then why would they be bad? I've heard that when the cats are clogged or bad the cats will get extremely hot. If you have a laser/digital thermometer you can point it on the cats and get a temp.
matthiasj said:
i heard you can unplug the o2 sensors, to relieve pressure and see how things go then.
some folks will drill a small hole just before the cat. if air is screaming out the hole, that can suggest a bad (plugged) cat. same idea but w/o the variable of the car running funky w/o its lambda hooked up.
