how to tell if its a roller block?
eightyfour said:
sorry if i seem like an idiot but i have no idea what that means
If you pull the intake off the motor you will see those letters stamped on the block in the lifter valley. Don't make the mistake of just picking up any 5.0 roller block. Get an '87-'92 motor out of a 5.0 mustang or lincoln LSC; same exact thing. That way you get forged pistons, a decent stock cam, and decent factory heads to start with.
A lot of the lincoln LSC's end up in junkyards because of tranny problems. A lot of the engines in them (if maintained) still have great compression (because they generally weren't beat on like stangs) and you can sometimes get away with using the shortblock as is.
eightyfour said:
so which letter mean roller? thanks,
Three x's (XXX) or three y's (YYY); both letters indicate that you have a roller block.
Oh, and unless the motor in your '84 was replaced, it's not a roller block. The first roller blocks were put in '85's.
