HOW to unplug Wires??
  • Thread starter Thread starter 88GTMustang
  • Start date Start date Feb 6, 2004
88GTMustang
247
LA california
Feb 6, 2004
  • Feb 6, 2004
Ok The Engine bay in my 88 coupe is almost naked!! Im planning on sandblasting it and Repainting it nice and pretty. There are 2 Big wire looms i want to get out of there. One goes into the drivers side firewall and one in the passenger side firewall. How would i go about getting those out?
Like is there a plug inside the dash that will just unplug? Hoping its not too much of a headache!!... Thanks!
P
PRO50SC
1,012
Olney, Maryland
Feb 6, 2004
  • Feb 6, 2004
Look for either a 10mm or 5/16" (socket size) bolt that holds the 2 halves together. Can't remember which side of the fire wall it's on.
88GTMustang
247
LA california
Feb 6, 2004
  • Feb 6, 2004
Oh no $hit, So you gotta pull the insulation off aroung it first? And what is it kinda like a plug that holds them together?
P
PRO50SC
1,012
Olney, Maryland
Feb 6, 2004
  • Feb 6, 2004
it's called a gang plug. It's what holds all the wires that pass thru the firewall to either side.
88GTMustang
247
LA california
Feb 6, 2004
  • Feb 6, 2004
Damn that was quick, i am going to check it out tomarrow and see what i find!
88GTMustang
247
LA california
Feb 7, 2004
  • Feb 7, 2004
well i Took the insulation off from around the engine bay firewall area and saw no Bolts. I decided too look in side the car and man can't see nothing. am i going to have too pull all that $hit off from under the dash, there to detatch the wires?
gaslight
3,365
Maine
Feb 7, 2004
  • Feb 7, 2004
don't quote me but I think its in the engine compartment. should be in the middle of the plug. small bolt that holds the two halves together. You might have to scape away some of the tar on the plug to find the screw/bolt.
P
PRO50SC
1,012
Olney, Maryland
Feb 7, 2004
  • Feb 7, 2004
Agree. Sorry I forgot to mention where the bolt was located.
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
C
Electrical Under dash wiring
  • ChicagoMustang
  • Apr 17, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
  • Mindseye007
  • Aug 16, 2026
Mindseye007
