howling gears!!
  • Thread starter Thread starter vanwilder692
  • Start date Start date Nov 20, 2006
vanwilder692
9
Youngstown Ohio
Nov 20, 2006
  • Nov 20, 2006
i know this may sound dumb, but when i am decelerating either in 5th 4th or 3rd gear i am hearing a howling sound, however, when i throw it into neutral the howling stops no matter what the speed is, but, when i throw her back into whatever gear i choose, depending on the speed, the howling returns. everyone tells me the gears or axel bearing are on their way out, but i can't keep but think that the problem is the tranny, and not the rear end. any words of wisdom?? the rear end is after market 4.11's, but the tranny is also aftermarket, both changed at the same time, and the howling started after the swaps! gear oil with limited slip added, and also manual trans oil correct level and changed!
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Nov 20, 2006
  • Nov 20, 2006
if the noise goes away when in neutral and still moving I'd say tranny......but maby your are hearing the exhaust drown and than when you put it in neutral and let off the gas the exhaust noise goes away. hard to tell without hearing it in person
bullitstang1313
713
Indianapolis / Columbus, Indiana
Nov 21, 2006
  • Nov 21, 2006
I don't know what trans you are using, but a T-5 uses ATF and a TKO uses GM sychromesh. I don't know if this has anything to do with your sound issue, but I thought you might want to know.
vanwilder692
9
Youngstown Ohio
Nov 21, 2006
  • Nov 21, 2006
sorry i meant to say that the rear end has correct weight oil with limited slip additive, and the manual trans, has correct oil level as well.
F
fastranger347
59
york PA.
Nov 21, 2006
  • Nov 21, 2006
its probly your rear gears BECAUSE if you throw it in netrual you are taking the compression load of the engine off of the gear set, with no load, no noise, you also have the noise on acceleration but you can hear it over the exhaust
1991vert
1,103
Ludlow, MA
Nov 21, 2006
  • Nov 21, 2006
hey, guess what? the driveshaft still turns in neutral, therefore so don't the gears.
the rear end doesn't know what gear you're in so if it only does it in certain gears, it's more than likely your transmission.
F
fastranger347
59
york PA.
Nov 21, 2006
  • Nov 21, 2006
um hey guess what; if its in netrual is it trying to pump 8 cylinders with out the throttle body being opened up? um ,no! the engine is idleing on its own without any help or hinderence from the trans or drivetrain, gears ( whether they be in the trans or rear) dont wear out from letting your car coast in netrual they wear from thrust,shear,and torsenal loads that can only be created by LOADING the drivetrain; the reason he might not hear it in 1 or 2nd is the rpm is higher on the engine (making more noise) AND the ring and pinion speed might not be high enough yet to produce the harmonic created by irregular wear on the tooth face, BUT the increased axle speed of 3rd,4th,5th Obviously allows the resonance frequency to be more pronounced; but your right on one thing the rear doesnt know which gear the trans is in, i dont think the rear really cares either
F
FOXtool
12
  • Nov 21, 2006
VERY WELL SAID FR347, I AGREE WITH WHAT YOU SAID. SOME PEOPLE JUST DONT UNDERSTAND.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Nov 21, 2006
  • Nov 21, 2006
foot on the gas= gears under load
foot off the gas = gears not under load
Mikie
the ahead of you horseman
Aug 2, 2000
517
Belmont NC
Nov 22, 2006
#10
  • Nov 22, 2006
  • #10
You are correct. Dont worry about your tranny as I can promise you that you have rear end problems. Been there, Done that!
Same symptoms exactly...and the culprit is ( drum role ) Aftermarket gears.
I can bet you have a set of Richmonds in there. I used them once and after a while they started whinning pretty good. Especially on the decceleration.
Dont get me wrong, Im not saying that all aftermarket gear companies are junk. I have seen from first hand experience that your odds of getting a bad set increase substancially when using the aftermarket companies gears.
GT_Rich
172
North Canton, OH
Nov 22, 2006
#11
  • Nov 22, 2006
  • #11
A couple comments:
1. I 100% agree with FR347.
2. Roland69: Foot on the gas = gear under load. Foot off the gas = gears still under load IF the car is still in gear. Only difference being direction of loading is reversed (i.e. - you slow down faster in gear than in neutral with you foot off the gas). In fatigue analysis, a cycle is often defined by the transition between loading the gears via acceleration vs. deceleration.
3. I'll agree with the culprit being aftermarket gears. I have the same noises (only in 4th and 5th for me). I'm running Richmond 3.73's. I know Richmond uses a different style gear tooth (straighter cut) which is supposed to be stronger, but in turn produces more noise. Not sure about the other aftermarket gear sets.
ronburgundy
179
BC coast
Nov 22, 2006
#12
  • Nov 22, 2006
  • #12
its the rear, 4th gear in the tranny should NEVER make noise.
Mikie
Aug 2, 2000
517
Belmont NC
Nov 22, 2006
#13
  • Nov 22, 2006
  • #13
I have also heard that...about the strength. I checked Richmonds product line and found that they have a 3.73 thick gear and a regular one...hmmmmm
Sounds like if you could put up with the mild howling of the thick gears then you would have a stout setup for launching at the track.
F
fastranger347
59
york PA.
Nov 22, 2006
#14
  • Nov 22, 2006
  • #14
im running motive gear 3.90's
1991vert
1,103
Ludlow, MA
Nov 22, 2006
#15
  • Nov 22, 2006
  • #15
you get what you pay for. crappy install is also possible.
vanwilder692
9
Youngstown Ohio
Nov 23, 2006
#16
  • Nov 23, 2006
  • #16
you guys are all awesome! thanks alot for the comments, and ideas!! and yes they are richmond gears from summit, the problem is that both rear end and tranny came from a 91 notch back that was strictly strip, looking back not knowing how many 1/4 runs where on the rear and tranny i made a bad choice. but its all part of learning. (but expensive)!!
1fastsn95
122
Carthage, tn
Nov 23, 2006
#17
  • Nov 23, 2006
  • #17
I think Richmond produces 2 types. One for racing purposes and one for street duty. The one for street duty is machined a litle more for a quieter ride, whereas the one for racing/off road is not. You wouldnt care if one howls a little in an all out race car, but you would want it to be stronger. This is what I have heard anyway.
Drivetrain How much resistance, if any at all, is normal on a new 1st gear and synchro on a WC T5 transmission?
  • sleep-e
  • Jan 21, 2026
Fox 5.0 Mustang Tech Jan 22, 2026
sleep-e
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Speedometer Calibration
  • Sonny Bibb
  • Sep 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 13, 2026
Sonny Bibb
Dipstick Issue?
  • Sonic
  • May 2, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 5, 2026
WhiteCobra95
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
