As already mentioned, either tires or wheel bearing are your most probable causes.
If you rule it out to not be tires, make sure you check each bearing (ALL 4!!) with a stethascope to save yourself lots of trouble. You would be amazed how far a noise will travel and where it can "sound" like its coming from.
Also, typically wheel bearing noises will get worse/change/go away when turning, such as getting better/worse when turning left/right or going around a curve. Thats a tell tale sign you have a wheel bearing issue as you add or remove load from a particular bearing.
