  • SN95 4.6L Mustang Tech
howling in engine bay
  • Thread starter Thread starter Torinalth
  • Start date Start date Jun 14, 2005
T
Torinalth
952
Clayton NC
Jun 14, 2005
  • Jun 14, 2005
i really dont know what it is in the slightest, so i'll do my best to describe whats going on and see if yall have any thoughts.
well, from what i can tell it only happens when i first start the car after it has been sitting for a while. i start the car and when it comes down to idle (~750rpm) there is a noticible "howling" sound comming from the front of the car. i opened the hood and poked around, but couldnt see anything out of place. sound SEEMS to be comming from the drivers side of the engine near/at the front. does not matter if the lights, radio, or ac is on at the time. also does not go away when i depress the clutch or brake. if i play with the gas it will go away once i get the RPMs passed 1500, then return once it goes below that point. after i run it for a bit it goes away entirely even at idle. if you turn it off and start it back up it is still gone.
this howling sound has seemed to get a bit worse and is now starting to draw my attention more often. the best way to describe the sound is if you take a larger margaritta glass, put lime around the outside, then run your finger around the edge to get that "harmonic vibration" sound. I'm realy lost on this one.... any ideas?
Torinalth
dsg_gt2004
423
Georgetown,SC
Jun 14, 2005
  • Jun 14, 2005
could it have anything to do with the Throttle body and plenum??
T
Torinalth
952
Clayton NC
Jun 14, 2005
  • Jun 14, 2005
i thought about that, but it has not had any issues so far, its all tight against everything else..... and it seems to be comming from farther forward on the block...
T
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jun 14, 2005
  • Jun 14, 2005
I think it is an idler pulley getting ready to seize. Cost to fix $15. Time to fix 5 minutes...
Take the belt off and check the pullies just by feeling them...
slow96mustang
146
romulus mi
Jun 14, 2005
  • Jun 14, 2005
someone sneak a blower in on ya, then take it back off once you drive it for a little bit?
check your alt if its not a pully. they make funnie noises too sometimes.
T
Torinalth
952
Clayton NC
Jun 14, 2005
  • Jun 14, 2005
think its the idler ehh KT? i'll give that a shot and see what i can find.
T
flashstang04
154
Wichita Falls,Tx
Jun 14, 2005
  • Jun 14, 2005
couldn't a vacuum leak cause that as well?
Nater
239
Maplewood, MN
Jun 15, 2005
  • Jun 15, 2005
Try doing a search on this as it was brought up a long time ago. I don't remember what the results were though; maybe something to do with the throttle body. My 2000 GT had the same issue with a cold start. Sounded like you were blowing into an empty Coke bottle. But once the engine warmed a little bit it would go away. Wouldn't heard the driveability and I could not find out what it was. Hasn't done it on my 2002 GT to date and I thought that the issue was corrected by 2001.
On a cold start, open the hood and have someone start the car to see where it is coming from.
R
redstangracer17
27
Abbottstown PA
Jun 15, 2005
  • Jun 15, 2005
hey, i just fixed a ford taurus with the same problem, it was the idle air control valve, some of them have little fins that will start to raddle together to make a loud humming noise
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jun 15, 2005
#10
  • Jun 15, 2005
  • #10
IACs are a known problem, I think that could be it Only $59 for a new one...
blackstalion666
177
New Jersey
Jun 15, 2005
#11
  • Jun 15, 2005
  • #11
more then likely its just coming from the intake and nothing to worry about
flashstang04
154
Wichita Falls,Tx
Jun 15, 2005
#12
  • Jun 15, 2005
  • #12
Yeah, if you are still driving fine, dont worry about it.
blackstalion666
177
New Jersey
Jun 15, 2005
#13
  • Jun 15, 2005
  • #13
i say this becuase after installing many cold air intakes on all types of vehicles most would make that type of noise. and yes it could be a vacuum leak . but if there was the engine light would come on.
flashstang04
154
Wichita Falls,Tx
Jun 15, 2005
#14
  • Jun 15, 2005
  • #14
Find someone with a predator to give it a look, maybe something will show up.
csledd
Official Ovary Punching Member
1,115
Paducah, KY
Jun 18, 2005
#15
  • Jun 18, 2005
  • #15
I'm having this same problem after I installed my TB and plenum. I'm not throwing any codes. Think I should just replace the IAC? The TPS broke a day after the install so maybe that went bad too? GRR. It doesn't seem to be effecting anything but it's not my favorite sound in the world. I guess I'll just replace that damn thing and find out
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 5, 2026
AeroCoupe
Clicking sound from driveshaft/rear differential
  • matthewt
  • Aug 27, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Aug 28, 2026
matthewt
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
