HP Estamation
Hey guys i was wondering what u guys think my motor is gonna have, ill list the mods
351 W
.40 over
JE flat tops
Afr 185s
eddy air gap intake
ill be calling comps cams for a custom grind cam and lifters
not sure on rockers? im leaving that to you experts to help me with
750 holley double pumper
LT Mac headers 1 3/4 or 1 5/8
and when thats all said and done a 150 shot of the good stuff
thanks!
I think this is one you are going to need a dyno for. I've seen some really good and really bad 351 dyno numbers here.
If those track numbers in your sig reflect a run with these parts, there's something seriously wrong.
If your rwhp after the cam is less than 425rwhp, i'd be worried.
What compression ratio are you expecting? Also i think you'd be better off with a Vic. Jr but the air gap is a good intake. I'd go with 1.6 rockers and let the cam handle any extra lift you want.
the numbers in my sig are with a unknopwn cam not the 280 solid lift...i was on just regular street tires and it was my first time at the track...and that is not with the new combo i listed thats my old combo...im new to the whole motor business where this is going to be my first...im not sure on the compression ratio. Anyone else have a idea?
i have 1.6 RRs at home from my old combo should i just use them or buy new ones?
Personally i wouldn't play with the rocker ratio unless you've crossed all the T's and dotted all the I's and can't squeeze that last bit of power out to make a goal or something, especially if you're shopping for a cam anyways because you can just get the lift that you want with the cam and not have to play with valve train geometry and lash and all that silly crap. I'd find out what pistons you've got and check into the manufacturer and see what compression they think it'll hit.
Out of curiousity how do you know JE flat top pistons are the right choice for this situation?
Not saying they are wrong, because i truely don't know, but there seems to be a few unknowns here, and when you get up there in a big dollar project, every part needs to compliment the combo, or else you land up with an expensive pile of junk.
