"humming" noise under light load?
BlackVert
5,589
9
98
Bethesda, MD
between about 15-25% load, i can hear a sort of a humming noise from the engine compartment. i thought it was the power steering pump, but i just replaced it and the noise is still there.
could it be this pulley? is this the idler pulley? is mine bad?
Its could be your trans? I dunno. It sounded like a whinning noise in the engine compartment just before my trans went. Now with the new one the whine is gone. And the whine only came along under load.
Hope this helps. This was my experience with the noise you describe.
jetuomi said:
hmm, how do you know your load #'s?? Could it be timing chain? Could you record the sound and post it up?
i have a tweecer. you can datalog the load.
i don't know if it could be the timing chain or not. i'll see what i can do about recording the noise.
it also happens in neutral while idling, if i feather the gas. i don't know if that rules out the tranny or not.
does that pulley in the picture look ok?
