  • SN95 4.6L Mustang Tech
HVAC controls aren't working :(
  • Thread starter Thread starter 9646gt
  • Start date Start date Apr 15, 2005
9646gt
595
Holloman AFB,NM
Apr 15, 2005
  • Apr 15, 2005
HVAC controls aren't working FIXED update and fix inside
Well I finally got my car running great thanks to everyone on here that helped me..I get in the car this morning and the heater blowed fine but I turned it off as soon as I had started the car...My heater gets hot and my ac gets cold ..I can even adjsut the fan speed with out a hitch..but it ONLY blows out the defroster vents....So I know it must be a vacum right? Well where would I check those on a 96gt? The only thing broken that I see is right nest to the TPS under the hood is another looks like platic plug going into that and it looks to have two plastic red vacum lines running to it..top one is broken and bottom one seems fine..if thats not where it runs to what is that line for any ways? And where is the simpleest place to start trouble shooting this thing? Fix Or Repair Daily lol its worth it tho so if someone can help me I would appreciate it..thanks a million guys..
FIXED..
On the 4.6 mustangs next to the TPS on th throttle body there is a plastic plug running into the intake..On this peice there are two red plastic vacume lines if the top one breaks you will not be able to switch where your A/C or Heat comes from on the HVAC controls ( heater A?C controlls on the dash) to fix it simply put a rubber vacume line over the top of the broke peices to hold them back together..it must be tight to create a good seal and vacume again..take about 30 seconds of the car running to be able to adjust it again..Hope this helps some people out!
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Apr 15, 2005
  • Apr 15, 2005
FIXED..
good job... BTW was it the wires or the coil pack? on your other problem
9646gt
595
Holloman AFB,NM
Apr 16, 2005
  • Apr 16, 2005
WIRES! You are awesome man..,,ou have helped me so much..if you ever need anything let me know bc I thought it was electrical (snesors) or fuel all along...
Mike97gt
it doe snot
10,633
Apr 17, 2005
  • Apr 17, 2005
thanks man... well we figured it out i really enjoy helping people with there mustangs.. PM me if you have questions anytime..
M
  • mnky99
  • Sep 5, 2025
mnky99
M
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
M
2001 v6 heater return pipe leak question
  • mnky99
  • Nov 11, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Nov 11, 2025
mnky99
M
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
P
High idle issue and leaking after running.
  • PHoffman
  • Dec 24, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 24, 2024
General karthief
