HVAC Vacuum Lines - How to Extend
93lx5.0
958
Fairfax, VA
Hey Guys,
I'm swapping my radio with my hvac controls in my fox, and I need to extend atleast one of the vacuum lines behind the hvac. Does anyone know what size they are? I believe they are 1/8", but I'm not positive. Also, if that's the case, anyone know where I can get connectors to connect two 1/8" tubes? The smallest I could find at the parts store was 1/8", and that's one size too big. Thanks in advance for the help.
Russ
Your local hardware store should be able to hook you up.
If not, I have used some metal or plastic line from the plumbing dept as a splice.
The Help or nuts/bolts aisle at the parts store might sell a little pack of white vac connectors as well. They go down pretty small as I recall.
Good luck.
I checked Home Depot, but no good. I'm gonna try Napa tomorrow. Can I use a vacuum line that's a little bigger for the extension? Can anyone confirm it's 1/8"?
Good luck.
