  • SN95 4.6L Mustang Tech
Hydroboost issue
  • Thread starter Thread starter 1fast03pony
  • Start date Start date Apr 25, 2004
1fast03pony
749
New york
Apr 25, 2004
  • Apr 25, 2004
After a rack swap, I step on the brakes and the steering wheel jerks to the right. Is this air in the lines or is something damaged?
krly79
464
VA Beach & So Illinois
Apr 25, 2004
  • Apr 25, 2004
It could be air in the line for your drivers side. If the caliper and the drivers side isn't compressing the pad then it would pull to the right. You could try it.
H
hotrod1431
  • Apr 25, 2004
I have had that problem before and it took me a long time to figure out what is was. It was the brake line itself that runs right into the caliper. What happens is overtime that rubber line breaks down on the inside and when you push the piston back into the caliper to put your brakes back on it forces that fluid in a upward direction which is opposite from what it normally does and it cause the rubber on the inside to fold up. Then you have less pressure going to one of your calipers causing the car to pull to the opposite side that you have the problem on. I hope this helps.
1fast03pony
749
New york
Apr 26, 2004
  • Apr 26, 2004
well it doesnt pull. It happens also when the car is standing still, the steering wheel sort of jerks and the pedal feels like it has a void, making me believe its air...
C
SN95 Another Coyote swap list
  • catkiller
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 8, 2026
bjornsn95
W
New here, 1967 getting an efi 348 stroker.
  • Weeman348
  • Mar 27, 2026
1965 - 1973 Classic Mustangs -General/Talk- Mar 27, 2026
Weeman348
W
H
Steering whine
  • healy1963
  • May 9, 2026
2005 - 2014 S-197 Mustang -General/Talk- May 10, 2026
gkomo
Drivetrain 1987 Mustang notch drive questions
  • Shannonfox123
  • Apr 12, 2026
Fox 5.0 Mustang Tech Apr 12, 2026
AeroCoupe
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
