I finished my blower install and have multiple problems.Where to start,I guess we'll start the oil leaks,vortech says no pipe dope or teflon tape on the oil feeds,but i've leaks at all the pipe fittings.Afraid I'm gonna strip or start breaking things.#2 running lean at idle gets a little better if you feed it a little gas.Talked to my brother he thinks it may be a vacum leak cause it is idling a little ruff and the connection to the boost retard box comes off real easy so i'm gonna cable tie all my vaccum lines,hoping that is the problemsince the fmu works off vaccum.I know the fmu is a bandaid but my budget is about shot,can't afford injecters and a tune at least not this year.# 3 boost gage is showing vaccum only no boost even if I give gas,I plugged of the throttle bodyand the port that used to go to the charcol canister.Or is it normal to show just vaccum at idle/part throttle.Any help would be appreciated
