I Broke The Bolt That The Front Swaybar Goes To The Frame
Yellow302
789
NJ
The title says it all.
It is a small clip with a stud coming out of it. There are two on each side of the frame that the swaybar mounts to. What is the name of this part?
This have been discontinued. I would appreciate any suggestions on how to get a replacement.
I took a pic as well.
Not sure what the specific name for that part is however... I THINK that the Steeda kit comes with all necessary hardware. You can upgrade your OEM sway bar for relatively cheap at the same time.
SteedaBrandon should be able to shed a little more light on it and also know if there are any additional mods necessary when changing the rear sway bar.
Noobz is correct. When I bought the Steeda front swaybar, rear swaybar and additional adjustable rear swaybar back in the day it came with all the hardware needed.
Looks like lots of salt corrosion, man that hardware is shot.
Yeah car sat in the garage with the dryer machine pumping humid air in for 900+ days. If you didn't open the garage it looked like a cloud in there. Mold growing on the seats, the damness deteriorated the carpet too.
The underbody surface rust on the car is terrible, already started wire wheeling it all off and using underbody rust sealer and barrier stuff, actully coming out nice. That is on hold untill I get get it up on a lift, its just too much to do on my back.
I already have new bushings, mount plates and link ends for the stock swaybar. Not looking to spend money where it is not really needed for me.
It is some sort of J-Clip or C-Clip. I dont see that hardware anywhere on steeda's website. I might have to call them.
Found it!
Fordparts.com
4PK
N806729-S150
STUD&RETAIN-M10X1.5X39WAFER SQ
This is the nut for the bottom... its showing 1x
N805474-S60
NUT-M10X1.5 HEX LOCKP/T NYLON
Found better pricing.
FORDPARTSGIANT.COM
Shopping Cart
Part No.DescriptionQty.Unit
PriceExt.
Price
**806729-S150 STUD
Replaced by: **806729-S436 4
Update
Remove $2.68 $10.72
**805474-S60 NUT-M10X1.5 HEX LOCK
Replaced by: **805474-S436 4
Update
Remove $1.89 $7.56
Calculate Shipping
UPS Ground $12.11
Subtotal: $18.28
Shipping: $12.11
Tax: $0.00
Total:
$30.39
