im making new brackets out of the old ones to eliminate the idler, tensoner, (alt will tension it) smog, and ac.. as long as the water pump pulley spins off the back of the serp. belt it will spin the correct way right?
yes as long as the belt is running off the back side of the serp it will be spinning in the correct direction.
Dood, tons of hot rodders use the alt as the tensioner, i know you have seen it.
http://www.coasthigh.com/Pulleys_Brackets/bracket_and_pulley_sets.htm
see how one bolt for the alt can slide? thats how you take out the slack
I've seen guys put their coil somewhere on the driver's side strut tower, thats around where they were mounted on the Fox cars with the longer coil wire. You'd only have to extend the harness going to the coil, which is easily done. Search for "power steering delete" or something along those lines, guys with no PS pump will have the coil mounted elsewhere.
