I dont get it
they seemed good quality,I think they were bendix.I did grease the pins and even if I didnt wouldnt that cause the car to pull as opposed to the brake pedal pulsing.Im gonna see if there is any runout with my dial indicator.I just cant believe that the rotors could be warped from the factory.
you may have some front end issues check the tie rods and ball joints for play and adjust rear brakes to ensure the front is not doing all of the stopping where did you buy the rotors i have had this problem in the past buying the cheap rotors from autozone and oriellys and advance autoparts in the past...and did you break in pads properly?
