  • 1994 - 1995 Specific Tech
I don't know what code 511 means, do you?
  • Thread starter Thread starter fastf50rd
  • Start date Start date Aug 2, 2004
F
fastf50rd
720
mass.
Aug 2, 2004
  • Aug 2, 2004
On my KOEO test i got code 511. This is an electronic control assembly problem, (eca) prob. Does anyone know what the eca is? Could this be causing my pinging problem.
chrismillion
20+ Year Stangneter
Mar 4, 2004
259
  • Aug 2, 2004
the 511 code is " Read Only Memory test failed-replace PCM" (Power Control Module)
Source: Haynes Repair Manual 1994 thru 2000
F
fastf50rd
720
mass.
Aug 2, 2004
  • Aug 2, 2004
So, what's this mean?
GTJake
3,049
Ann Arbor, MI
Aug 2, 2004
  • Aug 2, 2004
I got "EEC Processor ROM test failure."
No idea wth that means.
Jake
5.0_GT_kid
20+ Year Stangneter
Apr 18, 2004
1,155
Largo, Florida
Aug 2, 2004
  • Aug 2, 2004
That don't sound good
347 Special
78
las vegas
Aug 2, 2004
  • Aug 2, 2004
(O)
No power to PCM pin 1 or bad PCM (processor)
chrismillion
20+ Year Stangneter
Mar 4, 2004
259
  • Aug 2, 2004
i guess it means what it says,"replace PCM".
chrismillion
20+ Year Stangneter
Mar 4, 2004
259
  • Aug 3, 2004
you have supercharger so i guess you have a chip? if so, your chip is overiding some functions.
F
fastf50rd
720
mass.
Aug 4, 2004
  • Aug 4, 2004
Yeah, i found out anything pluged into the j3 port will throw that code.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Aug 4, 2004
#10
  • Aug 4, 2004
  • #10
347 Special said:
511
(O)
If this is true, hook up a volt meter to pin1 on the PCM and ground to the chassis. See if you are getting 12V.
If you are, then your PCM may be bad.
If you aren't, the wire is severed somewhere. Trace it all the way back to the wiring harness.
Scott
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
Need help ordering a oil cooler and filter relocation kit but don't know what I need
  • Aiden Brown
  • Aug 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 14, 2026
squeak93
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Fox Xtremely high fuel consumption
  • PonyGTrider
  • Apr 11, 2026
  • 9 10 11
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
PonyGTrider
