I got it started!!!!!!!!!!! BUT......Help
  • Thread starter Thread starter mustangsally93
  • Start date Start date Apr 25, 2006
1 of 2 Next Last
mustangsally93
281
Omaha,NE
Apr 25, 2006
  • Apr 25, 2006
Well most of you know that I was really having pormblems with getting my pony started.
Well after I got the engine back from the shop.(new rings,main,oil pump, timing chain,and homed and cleaned.
Well after all of that, me and a few buddys put it all back together and we got it runing good and everything. So after all of that I got 300 miles babyed on it(drove from omaha Ne, to manhattan Ks). Well I started it in the morning on monday when I seen my after market oil gauge was not working after 5 mins( it just went to 10psi and didn't move) and the stock gauge jumps around at ideal. From normal to nothing and I don't get it. But nothings wrong the cars doesn't ping or the rockers don't make noise. But if I drive the car for more then 5 mins the aftermarket gauge dosen't work, and the stock one does but at a light it moves around.
I'm lost again on this too. I must have oil pressure becasue the engine isn't making noise, since the gauge read 10 psi the engine should be crying.
I just don't know what to do, can you help?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 25, 2006
  • Apr 25, 2006
If you have any doubts about the gauges working, go to Home Depot's plumbing section and get a cheap mechanical gauge & a tee fitting. Add the gauge under the hood so you can watch it while working on the engine.
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Apr 25, 2006
  • Apr 25, 2006
Check the connection on your gauge. maybe the wire in loose on the sender or at the back of the gauge.... this could be the reason your gauge isn't reading correctly.
M
my289eatsrice
121
Woodstock, CT
Apr 25, 2006
  • Apr 25, 2006
The reason your stock gauge went to the ideal pressure is because it's set up on a switch. Mean, that unless your oil pressure drop below a certain predetermined mark, then it wont change. Meaning, that you oil pressure gauge reads the same from the day you drove it out of the dealer ship until now(15+years later). Do you think your engine really carries that same oil pressure? I agree w/ JRichter, go get an el cheapo mechanical to ensure that your aftermarket is working properly.
mustangsally93
281
Omaha,NE
Apr 25, 2006
  • Apr 25, 2006
ok I'll go do the cheap thing. But one thing, would I hear the lifter slaping if I had no oil pressure around 3 k?????
mustangsally93
281
Omaha,NE
Apr 25, 2006
  • Apr 25, 2006
also I could go drive around to make a video if that well help you guys help me too.
1SLO306
My 97 GTP owns you ALL!
Mar 31, 2005
904
Muhlenberg, ky
Apr 25, 2006
  • Apr 25, 2006
300 miles + no oil pressure= non running engine
I say u have oil pressure. What kind of mechanical oil pressure gauge u have?
ram360
2,162
Pennsylvania
Apr 25, 2006
  • Apr 25, 2006
I wouldn't f around with not know my oil pressure on a new motor....get a working gauge on it.
mustangsally93
281
Omaha,NE
Apr 25, 2006
  • Apr 25, 2006
well it runs fine other then the gauges say I don't have oil pressure. It only started doing this on monday I drove it back to kanasas and it was fine. The guage is auto meter and it worked since it was in the car about 2 years ago. I think the stock one is moving around it is because I dont have a good ground. But both gauge at once???? I think not................
1SLO306
Mar 31, 2005
904
Muhlenberg, ky
Apr 25, 2006
#10
  • Apr 25, 2006
  • #10
have u had the dizzy pulled since u put it back together?
i pulled mine a couple months after i got the car and the oil pump shaft fell into the pan cause the dipchit that worked on it before took the clip off and installed it from the top took me for ever to find out y i had no oil press
mustangsally93
281
Omaha,NE
Apr 25, 2006
#11
  • Apr 25, 2006
  • #11
no not since we put it all back in. It ran fine in tell I got here. Also it drives fine no noise. The stock gauge I think is a bad ground and I'm downloading video of the gauge and the car driving and stuff.
mustangsally93
281
Omaha,NE
Apr 25, 2006
#12
  • Apr 25, 2006
  • #12
Click here to watch MOV00227-75
this is the car first started
Click here to watch MOV00229-78
this is the car running
Mustang5L5
Mod Dude
Feb 18, 2001
43,374
18,121
224
Massachusetts
Apr 25, 2006
#13
  • Apr 25, 2006
  • #13
Only 20psi at 2000RPM is a little low, at that RPM you should be making full pressure which should be 45-55psi.
My 5.0 idles at 25psi warm and 55psi when about 1500RPM.
I agree that the stock gauge is screwed up. It should return to 0 when you turn the key to ON and start the car
mustangsally93
281
Omaha,NE
Apr 25, 2006
#14
  • Apr 25, 2006
  • #14
well I got about 200 miles on the car with the gauges being al messed up and I've had no problems with it. So this weekend I'm going to change out the auto meter and play with the stock one. Could it be air in the line or something, or a bad ground for the stock one. Also I took a friend out in the pony and look what I lost. It didn't mess it up. I'm loving this punch list of stuff getting bigger!!!!!!
mustangjoe87
364
Harrison Twp., Michigan
Apr 25, 2006
#15
  • Apr 25, 2006
  • #15
That happened to me one when I was racing a Trans Am. but atleast I was smoking him before the sparks started to fly.
mustangsally93
281
Omaha,NE
Apr 26, 2006
#16
  • Apr 26, 2006
  • #16
I just don't why both gauges aren't working. I hate this thing.............
L
livinitup1
vineland n.j.
Apr 26, 2006
#17
  • Apr 26, 2006
  • #17
whats water temp? if over 180 it will make a drop in oil pressure, and not bad idea to check pcv valve and vacume hose, mine fell off engine , oil pressure was low because of it. but could be just a wire grounding issue just putting out some alternative ideas. good luck
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Apr 26, 2006
#18
  • Apr 26, 2006
  • #18
Just adding some ideas to ya. my coupe did kinda the same thing. When it would get warmed up to operating temp and then SOMETIMES when i would stop and sit at a light it would read 0 psi of oil, but as soon as i would tap the throttle like maybe raise the r's up 100 it would go fine, it would also bounce around a bit as well. So i went to the parts store got a new $8.51 oil pressure sencer and it works just fine now! How are you running both gauges at once? peace
john
Mustang5L5
Mod Dude
Feb 18, 2001
43,374
18,121
224
Massachusetts
Apr 26, 2006
#19
  • Apr 26, 2006
  • #19
flush out the line going to your pressure gauge. I remember one time i mistakenly used teflon tape in the fitting of my fuel pressure gauge and it floated up to the gauge and caused false and low readings.
mustangsally93
281
Omaha,NE
Apr 27, 2006
#20
  • Apr 27, 2006
  • #20
john
Im running a line right out of the oil sencer unit. I'll take some pics today..
1 of 2 Next Last
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
  • dan50
  • Jul 18, 2026
dan50
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
