I got my powermaster
  • Thread starter Thread starter mustangman70
  • Start date Start date Jan 2, 2005
M
mustangman70
1,235
St pete, Florida
Jan 2, 2005
  • Jan 2, 2005
Allright i know that i just connect the red wire to the battery, but what do i do with the old regulator and those wires that are going to it, which wires do i eliminate ?????
Also i just orderd my lakewod traction bars too, do the springs have to be under a load when putting them on???
M
mustangdave
My rearend needs a stud and two nuts.
2,976
North Carolina
Jan 2, 2005
  • Jan 2, 2005
You just won't use the harness from the solenoid to the alternator. You can unplug the voltage reg. and remove or leave it alone as it will not be doing anything anymore.
M
mustangman70
1,235
St pete, Florida
Jan 2, 2005
  • Jan 2, 2005
So that plug into the regulater, and the harness to the alternator i can un-plug and take out of the car? Ive heard i have to tie them back and keep them in? also the black wire thats coming out of that "harness" that goes to the solinoid (the side that allways has volts) can i take that out too?
M
mustangdave
2,976
North Carolina
Jan 3, 2005
  • Jan 3, 2005
I don't think the plug for the regulator comes out, it is part of the harness. If you don't want it hanging there, you can tie it out of the way. The alt. to solenoid harness can be unplugged and removed. The only thing I haven't figured out with these alternators is how to make the stock gauge work.
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
A
Resolved Electrical Help Please
  • Alabama
  • Jan 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 22, 2026
AeroCoupe
  • brandyn200
  • Jun 20, 2026
AeroCoupe
F
Spark Plugs Caused Rough Idle & Driving
  • firevert
  • Sep 1, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 3, 2025
