I hate tires (burn out vids)
Blue Thunder
1,003
55
68
Upstate New York.
So here's a couple vids of my MII with the 332" stroker motor turning up a bit over 8000 RPM. It will smoke the tires up to about 70mph when starting in 3rd gear(manual-valve-body c-4) if I hold the throttle to the floor.
Rear tires are only 245/60R14s on factory Ford('71 mach?) 5-lug alum slot wheels. I'm really looking forward to the much wider tires that will soon be on this car. (and some granada rotors on the front, so I'll actually have matching 5-lug wheels all around)
Anyway, here it is:
http://www.worldofwargod.com/sitebuildercontent/sitebuilderfiles/stangii_2.mpg
http://www.worldofwargod.com/sitebuildercontent/sitebuilderfiles/stangii_1.mpg
(For speed reference here, the silver car on the other street behind me is going approximately 50-55 mph)
Mstng2 said:
Sweet mother motor!! Have you had that baby dynoed?!! I hope mine will haul tail like that when its done!
:nice:
I never had mine on the dyno, but it's twin sister 332 stroker was on an engine dyno.
The difference between the other 332 and mine was; That one was injected (It was installed into a 90s fox body) and had 10.5:1 (mine has 10.85:1) compression ratio, a slightly smaller profile solid roller cam, and mild cleanup work on the bowl areas of the heads, and it produced 530hp at 7100RPM. (flywheel hp)
IICrazy said:
all you need is to send the footage to me and I can edit it, and put it out on the final dvd.
I was tryin to help out haveII I have an old vhs camcorder I'm thinking about pitching
ps check your PM want to try some editing myself not just II stuff (you know Kids @ disney for grandparents ) --need your help thanks
