03/04 Cobra Part out Black & Torch Red
2003snake
52
Virginia
>>> CLICK HERE FOR PICTURES <<<
~~~ (Search Feature at bottom of page) - CLICK HERE FOR SPECIALTY PARTS ~~~
If you have any questions, please do not hesitate to contact me directly:
Jason - 757.641.7829, [email protected] / www.anchor-room.com
Updated: October 9, 2011
Under the hood
... >> Complete '03 Cobra Motor (50k miles) & 2.2 Kenne Bell, T56 Trans. W/Mc Cloud Clutch ( x 1 ) $8,500
... ABS Hard Lines (front of car) - Stock ( x 1 ) $110
... AC Accumulator - Stock ( x 2 ) $35
... AC Compressor - Stock ( x 4 ) $185
... AC Lines & Manifold (3 Lines 19835, 19972, 19D742 & Manifold 19D734) - Stock ( x 2 ) $270
... Alternator (rewound to 185 AMP! - **NEW**) - Stock ( x 1 ) $245
... Alternator Bracket - Upper - Stock ( x 1 ) $55
... Bassani Cats (2) - New, never USED - AM ( x 1 ) $95
... Battery Cover - Carbon Fiber - Series 58 - AM ( x 1 ) $95
... Battery Cover Series 58 - AM ( x 1 ) $25
... Belt - Accesory - Stock ( x 2 ) $10
... Belt - Bando 8pk1930 - AM ( x 1 ) $15
... Belt - Motorcraft - 2R3Z - 8620 - BC - Stock ( x 2 ) $20
... Belt - Napa MicroV AT - 080780 - AM ( x 1 ) $20
➫ Belt Tensioner & 100mm Pulley - Metco - AM ( x 1 ) $120
... Bolts - Alternator - Stock ( x 3 ) $20
... Boost hose cluster Complete - Stock ( x 1 ) $90
... Bolts - Exhaust manifold bottom studs (NEW) - Stock ( x 2 ) $10
... Bracket - Side of blower (with accessories) - Stock ( x 1 ) $55
... Brake (pressure distribution) Block - Stock ( x 3 ) $40
... Canton Windage Tray (All Ford 4.6L/5.4L) - **BRAND NEW** - AM ( x 1 ) $50
... Caster/Camber Plates (2) - Stock ( x 2 ) $40
... Clutch Cable - adjustable - AM ( x 1 ) $50
... Coil On Plug Covers - Stock ( x 1 ) $75
... Cruise Control Module cable (**BRAND NEW**) - Stock ( x 2 ) $35
... Cruise Control Module (No cable & Bracket) - Stock ( x 4 ) $75
➫ >>Eaton M112 -Super Charger - w/2.76 pulley - Stock ( x 1 ) $400
➫ >>Eaton M112 -Super Charger - w/stock pulley - Stock ( x 1 ) $350
... EGR sample tube - Stock ( x 1 ) $5
... EGR w/Tube & hoses - Stock ( x 1 ) $45
... Engine Wiring Harness (FI, Cops, Etc.) - Stock ( x 1 ) $195
... Evap Unit w/hoses - Stock ( x 4 ) $100
... Expansion Tank for Radiator w/cap - Stock ( x 3 ) $45
... Exhaust Headers - Stock ( x 1 ) $40
... Fan Assembly - Stock ( x 1 ) $130
... Filter (Air) Housing and tube - Stock ( x 1 ) $90
... Firewall Heater Hoses - Stock ( x 1 ) $75
... Fuel Evap Lines - Stock ( x 3 ) $75
... Fuel rails - Stock ( x 2 ) $40
... Fuel regulator - Stock ( x 2 ) $10
... Fusebox Bracket - Stock ( x 3 ) $20
... Guides, Tensioners, Gears, Chains - Stock ( x 1 ) $195
... Harmonic Balancer - Stock ( x 2 ) $180
... Headers (Bassani) - AM ( x 1 ) $395
... Heat exchanger - Stock ( x 5 ) $85
... Heat Exchanger hoses (3) - Stock ( x 1 ) $25
... Hood release latch and cable - Stock ( x 2 ) $30
... Horns - Stock ( x 2 ) $25
... IC pump hoses - Stock ( x 1 ) $30
... Idler Pulley - Grooved - Stock ( x 2 ) $22
... Idler Pulley - Smooth - Stock ( x 11 ) $12
... Intake 90* Elbow - Rubber - AM ( x 1 ) $10
... Intercooler (under blower) - Stock ( x 1 ) $375
... Intercooler hoses - 2 - Stock ( x 1 ) $30
... Intercooler overflow Cap - Red - AM ( x 1 ) $10
... Intercooler reservoir - Stock ( x 4 ) $45
... Intercooler Reservoir Cap - Stock ( x 1 ) $10
... Latch/Radiator front support - Stock ( x 1 ) $20
... Latch/Radiator front support bar (only bar) - Stock ( x 1 ) $5
... Lower hose to oil cooler - Stock ( x 1 ) $15
➫ Maf - 90mm - Stock ( x 1 ) $60
➫ Maf - SCT BA2400 - AM ( x 1 ) $195
... Master cylinder/booster - Stock ( x 2 ) $195
... Master cylinder/booster/lines - Stock ( x 1 ) $295
➫ Oil cooler/tube/filter assembly - Stock ( x 1 ) $400
... Oil seperator - AM ( x 1 ) $20
... Oval Throttle Body Clamp - Stock ( x 1 ) $5
... Power Steering Pump - Stock ( x 1 ) $100
... Power Steerring Fluid Reservoir - Stock ( x 2 ) $65
... Power Steering Fluid Reservoir Bracket - AM ( x 6 ) $100
... Power Steering Fluid Reservoir Bracket - Stock ( x 2 ) $175
... Power Steering Fluid Reservoir Cap - Stock ( x 1 ) $5
➫ Pulley Bridge (no tensioner) - Stock ( x 2 ) $275
... Radiator Support Brackets - Stock ( x 2 ) $15
➫ Red Line Tuning Hood Shocks **NEW**FREE SHIPPING** '05-'11 Mustang - AM ( x 4 ) $80
... Rubber Seal, Cowl - Stock ( x 4 ) $15
... Sensor - Crank Position - Stock ( x 1 ) $25
... Sensor - FRPS - Stock ( x 4 ) $50
... Sensor - (IAT) - Stock ( x 1 ) $20
... Sensor - IAC - Stock ( x 1 ) $75
... Sensor - TPS - Stock ( x 1 ) $25
... Starter - Stock ( x 3 ) $75
... Steering Shaft - Stock ( x 1 ) $75
... Strut Tower Covers (2 NEW) - AM ( x 1 ) $10
... Supercharger Plenum - Stock ( x 3 ) $65
... Swaybar Links with bushings - Stock ( x 2 ) $15
... Tensioner (w/pulley - 8 RIb) - Stock ( x 2 ) $50
... Tensioner (w/pulley - 6 Rib smooth) - Stock ( x 1 ) $50
➫ Thermostat Housing (!!BRAND NEW!!) - Stock ( x 1 ) $108
... Throttle Body - Stock ( x 4 ) $95
... Throttle Body Clamp and rubber gasket - Stock ( x 1 ) $10
... Timing cover - Stock ( x 1 ) $215
... Transmission Wiring Harness - Stock ( x 1 ) $100
... Upper Idler Bracket & Pulley - Stock ( x 1 ) $75
... Valve Cover Gaskets - Stock ( x 1 ) $9
... Washer Reservoir - Stock ( x 2 ) $30
... Water Pump - Stock ( x 2 ) $55
... Wiper Arm Assembly (Under cowl) (Both) - Stock ( x 4 ) $37
... Wiper Motor - Stock ( x 4 ) $35
Inside the car
... Air Bag - Driver - Stock ( x 4 ) $295
... Air Bag - Passenger - Stock ( x 4 ) $275
... Air Bag Module - Stock ( x 2 ) $145
... Amps (Coupe) - Stock ( x 2 ) $135
... Amps (Vert) - Stock ( x 1 ) $135
... Blower Motor/Heater Core and ducting from dash - Stock ( x 2 ) $135
... Car Jack - Stock ( x 1 ) $35
... Carpet (Black) - Stock ( x 1 ) $105
... Center console (**10TH ANN.**) - Stock ( x 1 ) $195
... Cigarette Socket (from shifter area) - Stock ( x 1 ) $5
... Coat hooks(2) - Stock ( x 3 ) $10
... Dash Cowl Piece (inside the car)- Stock ( x 2 ) $35
... Dash Wiring Harness - Stock ( x 1 ) $175
... Dead Man Pedal - Stock ( x 2 ) $10
... Defrost (small) vents - Passenger - Stock ( x 1 ) $10
... Defrost ducting - Passenger - Stock ( x 1 ) $5
... Defrost ducting & tube - Passenger - Stock ( x 1 ) $7
... Defrost large Windshield ducting - Stock ( x 1 ) $15
... Dome Light - complete - Stock ( x 1 ) $25
... Dome Light Lens - Stock ( x 1 ) $10
... Door Control Cup - 10th anninversary - (Driver & Passenger) - Stock ( x 1 ) $60
... Door electronics - (Passenger) - Stock ( x 2 ) $75
... Door electronics - (Driver) - Stock ( x 2 ) $75
... Door Handle - Set in Hydro Carbon Fiber - Stock ( x 1 ) $70
... Door mechanical latch & cable - (Passenger) - Stock ( x 1 ) $75
... Door mechanical latch & cable - (Driver) - Stock ( x 1 ) $75
... Door panel - Only the panel! - (Driver) - Stock ( x 1 ) $125
... Door panel - Only the panel! - (Passenger) - Stock ( x 1 ) $125
... Door Release Handle Cup (Driver) - Stock ( x 1 ) $10
... Door Release Handle Cup (Passenger) - Stock ( x 2 ) $10
... Door release Mechanism - passenger side - Stock ( x 1 ) $40
... Door release Mechanism, cable & Pull - passenger side - Stock ( x 2 ) $60
... Door Seal Bottom (passenger) - Stock ( x 1 ) $15
... Door Seal Top (passenger) - Stock ( x 1 ) $15
... Door Sill - small - Driver - Stock ( x 1 ) $20
... Door Sills (2) - Stock ( x 2 ) $50
... Door triangle Speaker mount (driver) - Stock ( x 3 ) $20
... Door triangle Speaker mount (passenger) - Stock ( x 3 ) $20
... Door triangle speaker mount weather seal - Stock ( x 1 ) $5
... Door Window seal inside and out - Stock ( x 2 ) $40
... Ducting - partial - from dash - Stock ( x 2 ) $25
... E-brake for Coupe - Stock ( x 4 ) $65
... Flasher relay - Stock ( x 2 ) $10
... Fpdm - Stock ( x 3 ) $55
... General Electric Dash Box - Stock ( x 3 ) $135
... Glove Box - Stock ( x 4 ) $35
➫ Guage cluster (50,xxx Miles) - Stock ( x 1 ) $270
... Guage cluster (49,xxx Miles) - Stock ( x 1 ) $275
... Guage cluster (67,528 Miles) - Stock ( x 1 ) $265
... Guage cluster (83,866 Miles) - Stock ( x 1 ) $240
➫ Guage Pod for Coupe (2 Guages) - AM ( x 1 ) $40
... Harness - Headliner - Stock ( x 2 ) $20
... Headliner Map Net - Stock ( x 1 ) $10
... Heater Control Knobs (3) - Stock ( x 1 ) $10
... Heater Control - Stock ( x 1 ) $30
... Heater Core - Stock ( x 1 ) $30
... Heater Duct unit - Stock ( x 2 ) $95
... Inertia switch - Stock ( x 3 ) $20
... Instrument Cluster Bezel - Stock ( x 1 ) $50
... Interior (Driver side) lower rear panel - Stock ( x 1 ) $60
... Interior rear panels (both sides) - Stock ( x 2 ) $120
... Interior rear sail trim panels (both sides) - Stock ( x 3 ) $80
... Jack, carpet and crowbar - Stock ( x 2 ) $50
... Kick panel - Driver Side (Coupe) - Stock ( x 1 ) $25
... Kick panels x 2 (Coupe) - Stock ( x 2 ) $50
... Knee Kick Panel and brace (under column) - Stock ( x 3 ) $45
... Light Switch Assembly (no knob) - Stock ( x 4 ) $15
... Main - 'inside the car' - Harness - Stock ( x 3 ) $190
... MGW Orange Handle - **NEW** - AM ( x 1 ) $25
... Mirror Controls (from driver door panel) - Stock ( x 1 ) $15
... OBDII Data Cable - AM ( x 1 ) $10
... PCM Harness - Stock ( x 1 ) $185
... PCM plastic Mount - Stock ( x 3 ) $10
... Pedal Set & Assembly (4 Piece - Clutch, Gas, Brake, Dead Man) - Stock ( x 2 ) $115
... Pillar - driver - Stock ( x 1 ) $40
... Pillar - passenger - Stock ( x 2 ) $35
... Quadrant - Reichard Racing Single Hook - AM ( x 1 ) $25
➫ Radio (6 CD Changer - Mach 460 - 03 Cobra) - Stock ( x 3 ) $115
... Radio (6 CD Changer - Mach 460 - 04 Cobra w/sattelite option) - Stock ( x 1 ) $125
... Radio plastic support piece - Stock ( x 1 ) $5
... Rear deck Speaker covers with grills (coupe) - Stock ( x 2 ) $35
... Rear Seat bottom rail - Stock ( x 2 ) $10
... Rear Seat Head rest - Stock ( x 2 ) $45
... Rear Seat top rail - Stock ( x 2 ) $10
... Rear View Mirror - Stock ( x 1 ) $15
... Rocker Panel small trim piece (w/'mustang' in it) - Stock ( x 4 ) $10
... Roof Rail (both sides) - interior - Stock ( x 1 ) $20
... Steering Wheel - Stock ( x 1 ) $100
... Shifter Bezel boot - (Only the boot) **Brand New** - Stock ( x 1 ) $75
... Seat Belt Loop (passenger Side) - Stock ( x 1 ) $15
... Seat Track Covers (Driver) - Stock ( x 1 ) $5
... Seat Track Covers (Passenger) - Stock ( x 1 ) $5
... Seatbelts (Rear 2) - Stock ( x 3 ) $50
... Seatbelt Covers (2) - Stock ( x 1 ) $10
➫ Seats (Coupe front & back) - 10th anniversary - Stock ( x 1 ) $1,700
➫ Shifter (Steeda Tri Ax) - AM ( x 1 ) $115
➫ Shifter (Steeda Tri Ax) No Handle - AM ( x 1 ) $105
... Shifter Base - Stock ( x 1 ) $35
... Shifter - Stock ( x 1 ) $50
... Shifter Bezel w/boot (**10TH ANN.**) - Stock ( x 1 ) $150
... Shifter Knob (**10TH ANN.**) some wear - Stock ( x 1 ) $25
... Shifter Knob (**10TH ANN.**) great shape - Stock ( x 2 ) $75
... Spare Tire - Stock ( x 2 ) $130
... Speaker cover, (Large for Convertible) Driver Side - Stock ( x 1 ) $20
... Speaker cover, (Large for Convertible) Passenger Side - NEW - Stock ( x 1 ) $25
... Speaker Panel (Custom made to replace rear speakers - for coupe) - AM ( x 1 ) $10
... Speakers (Coupe 4 sets including rear box) - Stock ( x 4 ) $95
... Steering Column w/keys - Stock ( x 3 ) $95
... Steering Wheel (**10TH ANN.**) - Stock ( x 1 ) $495
... Switches - Center of dash by shifter - Stock ( x 1 ) $30
... Super Chips Custom Tuning PCM Chip (cjjwdpwcrd 2004) - AM ( x 1 ) $75
... Trunk panel (rear - 2 pieces) - Stock ( x 3 ) $80
... Trunk rear center plastic panel - Stock ( x 2 ) $10
... Trunk rear panel - Stock ( x 2 ) $40
... Vent (heat/ac) - Driver - Stock ( x 1 ) $20
... Vent (heat/ac) - Passenger - Stock ( x 1 ) $20
... Visors (both) - Stock ( x 1 ) $40
... Visor - and assembly for convertible (Driver Side) **NEW** - Stock ( x 1 ) $95
... Window Motor (Pass) - Stock ( x 1 ) $40
... Window/Lock switches (Pass) - Stock ( x 3 ) $50
... Windows Electrical - passenger side - Stock ( x 2 ) $70
... Windows Electrical - passenger side W/1 touch down relay - Stock ( x 1 ) $80
Under the car
... ABS Sensors complete with wire & Plugs (2 - Back) Stock ( x 3 ) $75
... ABS Sensors complete with wire & Plugs (2 - Front) Stock ( x 4 ) $75
... Bassani 5 piece x pipe - AM ( x 1 ) $305
... Bassani Catless x pipe - AM ( x 1 ) $295
... Bilstein Strut (50k Miles) (Each) - Stock ( x 1 ) $110
... Bilstein Shock (Each) 50k Miles - Stock ( x 2 ) $65
... Bilstein Shock (Each) **NEW** - Stock ( x 2 ) $95
... Bilstein Shock (Each) 40k miles - Stock ( x 1 ) $70
... Bilstein Shock (Each) 7k miles - Stock ( x 2 ) $80
... Brakes ( Calipers, Bracket, Line, Pads - Rear) - Stock ( x 2 ) $180
... Brakes Lines - Rear) - Stock ( x 1 ) $15
... Catback - Dynomax - AM ( x 1 ) $285
... Canister, Bracket, Solenoid - Fuel Evap - Stock ( x 2 ) $190
... Convertible K-member support brace - Stock ( x 1 ) $90
... Drive shaft (w/rear yoke) - Stock ( x 1 ) $215
... Drive shaft (w/front & rear yoke) - Stock ( x 1 ) $255
... Emergency Brake Cables (all 3) - Stock ( x 1 ) $65
... Exhaust Hangers (each) - Stock ( x 4 ) $2
... Fender Liner - Driver - Stock ( x 1 ) $40
... Front Clip w/K member - Complete from the Strut Towers Forward - Stock ( x 1 ) $550
... Front Spoiler (has scapes) - Stock ( x 1 ) $20
... Front sway bar - Stock ( x 3 ) $75
... Fuel Filter Bracket - Stock ( x 5 ) $9
... Fuel Line 8an black braided (7 feet) - AM ( x 1 ) $10
... Fuel pump socks (2) - AM ( x 1 ) $5
... Fuel pumps (1) - Stock ( x 11 ) $45
... Fuel tank - Stock ( x 1 ) $415
... Fuel Tank Filler neck (includes basket and gas cap) - Stock ( x 2 ) $95
... Fuel Tank straps and retaining pin - Stock ( x 1 ) $20
... IRS **Local Only** - Stock ( x 1 ) $850
... IRS (With Braces (2) and bushings) **Local Only** - Stock ( x 1 ) $1,225
... IRS Mounting Brackets - Stock ( x 1 ) $45
... K-member assembly (no A arms) - Stock ( x 3 ) $190
... K-member support bar - Stock ( x 1 ) $20
... O2 sensors (x2) - Front - Stock ( x 1 ) $45
... O2 sensors (x2) - Rear - Stock ( x 3 ) $45
... Radiator Support Brackets - Stock ( x 2 ) $10
... Rear Anti Vibration Weight & Bracket- Stock ( x 1 ) $25
... Rear evap Lines - Stock ( x 3 ) $75
... Rotors (Front - 2) - Stock ( x 2 ) $165
... Rotors (Rear - 2) - Stock ( x 3 ) $68
... Spindle/Hub/Dust Shield x2 (front / No ABS - Left & Right) - Stock ( x 3 ) $225
... Splash Guard - Stock ( x 3 ) $5
... Spring Spacers (2) - AM ( x 2 ) $5
Coupe springs H&R (Race 51659-88) **BRAND NEW** - AM ( x 1 ) $210
... Springs (Coupe) - Stock ( x 1 ) $40
... Tranmission Tunnel boot/cover - Stock ( x 2 ) $20
... Transmission Mounts - Stock ( x 2 ) $35
Exterior and More
➫ 03 Cobra Terminator Spoiler (DSG) w/3rd Brake Light - small crack - Stock ( x 1 ) $450
➫ 03 Cobra Terminator Hood (DSG) - Stock ( x 1 ) $550
➫ 3rd Brake light 03/04 Cobra - Brand New - Stock ( x 13 ) $190
... Bumper - Front (metal support) (NOT THE COVER) - Stock ( x 1 ) $235
... Bumper - Front support mount - Stock ( x 1 ) $10
... Bumper - Rear (metal support) and Foam (NOT THE COVER) - Stock ( x 3 ) $190
... Cobra Front Grill Plastic - Stock ( x 1 ) $50
... Cobra side emblems (2) - Stock ( x 1 ) $15
➫ Diablo Predator (unl.) U7142/03-04Cobra- AM ( x 1 ) $175
... Door glass & mounting assembly (Driver) **Local Only** - Stock ( x 2 ) $150
... Door glass & mounting assembly (Passenger) **Local Only** - Stock ( x 1 ) $150
... Door Handle Exterior (Black - Passenger) - Stock ( x 1 ) $15
... Door Hinges - Upper & Lower (Driver) - Stock ( x 3 ) $55
... Door Hinges - Upper & Lower (Passenger) - Stock ( x 2 ) $55
... Door Latch (Driver) - Stock ( x 4 ) $10
... Door Latch (Passenger) - Stock ( x 3 ) $10
... Door Molding Gasket (Driver Side) - Stock ( x 4 ) $25
... Door Molding Gasket (Passenger Side) - Stock ( x 3 ) $25
... Door Molding Strip Under 1/4 Window (Driver Side) - Stock ( x 4 ) $15
... Door Molding Strip Under 1/4 Window (Passenger Side) - Stock ( x 4 ) $15
... Front Bumper Support Foam - Stock ( x 1 ) $40
... Fuel door stop (set of 2) - Stock ( x 1 ) $10
... Fuel door - Black - Stock ( x 1 ) $50
... Mirrors (Flat Black - Driver & Passenger) - Stock ( x 1 ) $395
... Mirrors (Mystichrome - Driver & Passenger) - Stock ( x 1 ) $395
... Mirrors (Red Fire - Driver & Passenger) - Stock ( x 1 ) $425
... Tail light - Passenger - Stock ( x 1 ) $55
... Rear glass (1/4 Panel - Driver) - Stock ( x 4 ) $55
... Rear glass (1/4 Panel - Passenger) - Stock ( x 4 ) $55
... Rear glass (windshield) **Local Only** - Stock ( x 4 ) $75
... Rear Tail lights (2) - Stock ( x 3 ) $95
... Sail Panel (Driver Side - Torch Red) - Stock ( x 1 ) $70
... Sail Panel (Passenger Side - Silver) - Stock ( x 1 ) $70
... Sail Panel (Passenger Side - Torch Red) - Stock ( x 1 ) $70
... Stock rubber plugs/vents - Stock ( x 2 ) $25
... Trunk Latch - Stock ( x 4 ) $10
... Trunk Rubber Seal - Stock ( x 3 ) $15
... Trunk shocks - Stock ( x 2 ) $40
... Underhood Cowl piece - Stock ( x 1 ) $40
... Wheel Locks & 1 Key (set of 4 - Used - Brass - McGard) - AM ( x 1 ) $20
... Wheel Locks & 1 Key (set of 4 - Used - Chrome - McGard) - Stock ( x 1 ) $25
... Wheel Lugs (*NEW* - set of 20 - 1/2" x 20) - AM ( x 1 ) $50
... Window - Passenger - Stock ( x 1 ) $95
... Window Track/motor - Passenger - Stock ( x 1 ) $55
➫ Wiper Cowl - OEM / Brand New in the box from Ford - Stock ( x 2 ) $180
➫ Windscreen for vert with lightbar (Brand NEW!!!) - AM ( x 1 ) $165
Miscellaneous
➫ Ford Ranger tail gate plastic 97+FD / f77j-9940726-ad - **NEW** - Stock ( x 1 ) $25
➫ 99-'10 Drvr Dr Hdle/FSeries Trcks / 7c3z 2522405 aa / **NEW** - Stock ( x 1 ) $20
➫ 3rd Brake Light Mustang /'05-'09 / 6r3z 13a613 a / **NEW** - Stock ( x 1 ) $30
➫ Tail Light Mustang / Passenger / 5r3z 13404 aa / **NEW** - Stock ( x 1 ) $75
Prices:
Most prices are firm, a lot of time went into researching what this stuff sells for, and I mean what it actually sold for, not could sell. Prices often fluctuate even on our local forum depending on supply and demand or knowledge of the product. Don't get mad when something sells because you did not act quick enough, we all know there is a demanding market for all this stuff - the one who acts quickest gets the product!! The more you buy, the more likely I am to 'cut you a deal'.
Parts Availability:
Most parts have been removed from car(s) and are available immediately. Some however are not, please be patient. Thanks!
Payment
I gladly accept Paypal, there is however a fee they charge - 3%. I also accept Western Union which is available in more places than you can imagine (we have one at the local Food Lion). Credit Cards are also an option through PayPal, I would just need to send you an invoice.
Shipping
If the item is easy to remove from the car, or it already has, it will ship the next morning, or the same day! Iitems will ship with either USPS, UPS, or Fed Ex - believe it or not, often UPS and FedEx have the best rates and fastest shipping. If I do ship with USPS, they do NOT offer package tracking, they call it 'delivery confirmation'. Sometimes shipping with the USPS takes a tad longer (up to 9 days, not counting Sat & Sun.) If there is snow on the ground sometimes even longer. If you want to insure a package it is up up to YOU to say so. I have never (knock on wood) had any issues with damage or missing packages, my mission is to get the part to you the cheapest/fastest way possible. I will gladly ship almost anything on the above list (except for items marked ** Local Only**) - serious inquiries only please!
Advance Payment, Securing, and Shipping
If there is a larger item on the list that I do not readily have, or can get a shipping quote for (like heads or a short block) I have in the past accepted payment (securing your purchase and ownership of the item), then boxed it up and taken it to UPS in order to receive a proper quote. After receiving the quote contacted the buyer (for shipping payment) and upon receipt shipped the item. No issues, buyer does not overpay for shipping, everybody is happy!
Parts Sold:
Door panel driver (Complete with cups) - Stock
Door panel passenger (Complete with cups) - Stock
Custom Chip - 'SuperChips - Custom Tuning' w/ 7 pos. removable switch - AM
PCM (Coupe) - Stock
Light Switch knob - Stock
Seats (Coupe - Rear) **Local Only** - Stock
Parts Sold:
Center Console Plactic Cup Insert - Stock
Bumper - rear cover (Black) **Local Only** - Stock
Trunk, Spoiler, 3rd Brake light combo - (WILL NOT SEPERATE) **Local Only** Torch Red - Stock
Side Scoop (Passenger Side) (Torch Red - 1 Scratch) - Stock
Side Scoop (Driver Side) (Torch Red - 1 Scratch) - Stock
