  • SN95 V6 Mustang Tech
Fuel I Have 99 V6 Mustang And It Appears To Not Be Getting Gas.
  • Thread starter Thread starter Rob Standard
  • Start date Start date Dec 21, 2014
How do you check and see if its getting fuel to the injectors?
  • Fuel line stopped up.
    Votes: 0 0.0%
  • Not enough gas in fuel tank.
    Votes: 0 0.0%
  • Total voters
R
Rob Standard
  • Dec 21, 2014
Hey folks my mustang has been sitting in the garage for two months and it wouldn't start. I found that the battery was dead and I replaced it. The car turns over but it will not fire up. I can hear the fuel pump turn on but not sure if it is delivering gas to the injectors. I have less than a 1/4 tank of gas. Is there a way for me to see if the fuel is getting to the injectors? What else could it be?
Gt Byron
33
Dec 21, 2014
  • Dec 21, 2014
Since you haven't started in so long it could be floted I would try to keep cracking a few more times and for longer time and see if she will turn over or to unplug the fuel pump fuse and keep trying to crack if till all that gas clears out then plug the fuse in back in and and keep cranking i can't think of any other reason for the car not to start if it was only sitting for a couple of months and once you get it on let it run a little while and I would suggeste staring it up once a week
midsprat123
  • Jan 30, 2015
An easy but messy way to check this would be to remove the fuel line that feeds your fuel rail, have someone turn the key over and see if fuel is coming through the lines. Would suggest getting a bottle and sticking the end of the hose in to catch any fuel that may spurt out. To remove the fuel line, you just need to buy a fuel line disconnect tool for it
G
  • Poll Poll
I got a free Mustang from Grandma
  • GrannysMustang
  • Mar 4, 2026
  • The Welcome Wagon
The Welcome Wagon Mar 6, 2026
Realmongo
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sunday at 2:52 PM
JohnKay
J
J
Fox 1986 V6 Fuel/Electrical Issues, crank, no start, turns over with starting fluid
  • JlChamberlain
  • May 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2025
gkomo
Engine won’t start at operating temp.
  • SethB0601
  • Sep 30, 2024
SN95 V6 Mustang Tech Oct 26, 2024
Mustang5L5
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
