I Melted another clutch cable help!
bdazzgt
I had to jerk off the cable to get it to stop.
Dec 27, 2005
328
Springfield MO
So in November my adjustable clutch cable of 5 years broke at the plastic piece at the firewall, I bought another cable from LRS put it on no problem then it started binding up at the bellhousing. When I pressed in the clutch it would form a S shape at the bell housing. So I searched the forums and realized that i had the cable routed wrong. It was routed next to the steering arm under the motor mount above the k-member. I put the new one on, it worked flawlessly. I routed it under the motor mount above the steering rack which is apparently the OEM way of running it. I had bolted the bracket to the frame rail. So im driving today and the clutch pedal just falls to the floor like the cable came loose. I get out and it has melted all the way through except the steel cable. So i have to have it towed home again.... My question is that i have equal length shorty headers. What are my options, the cable was about 1-1.5'' away from the header tube #2 on driver side but if i unbolt the cable its very close to tube #1. What are my options? I dont mind buying heat wrap but this seems as if there should be a different way to fix the problem. Thanks guys
I'll be looking into these if/when my original stocker ever gives up....
http://www.maximummotorsports.com/s...50_160&zenid=55ecef8ca21720b1bdcf63b5b6d27546
Clutch cable for Mustang fitted with a firewall adjuster and aluminum quadrant
  • Made in America for MM by the original Ford OEM vendor.
  • This is not the same clutch cable sold by FRPP.
  • All FRPP clutch cables have a completely different, non-OEM design and construction.
  • FRPP clutch cables are made in Taiwan.
  • Requires a firewall adjuster. Will not fit without a firewall adjuster.
This item:
One Mustang clutch cable, ready for use with a firewall adjuster.
Benefits
  • Provides the same smooth and low-effort pedal motion as the original stock clutch cable did when your Mustang was brand new.
  • Maintains low-friction operation even with heavy clutch loads.
  • Ready for fitment to a firewall adjuster; no need for the installer to modify the end of the housing.
  • Available in a money-saving package with a quadrant and firewall adjuster
  • Longer than many of the stock Mustang cable assemblies, allowing it to be routed away from the exhaust.
Unlike offshore-sourced clutch cables:
  • Tough OEM cable housing does not easily collapse.
  • Inner cable glides effortlessly inside a low-friction Teflon sheath.
  • Multi-layer outer housing provides greater heat resistance.
  • Strong OEM inner steel cable is more stretch resistant.
Product Features
  • OEM design and construction: That's why it works better.
  • OEM design and construction: That's why it lasts longer.
  • Multi-layered OEM housing, unlike all other Mustang clutch cables, from both the aftermarket and FRPP.
  • Steel-strands have a low-angle spiral and secondary binding, providing greatest longitudinal strength, and very high resistance to collapse.
  • Low-friction Teflon inner sheath, unlike other clutch cables.
  • Designed for easy installation with a firewall clutch adjuster.
Notes
  • Requires a firewall adjuster. Cannot be installed on a Mustang that does not have a firewall adjuster.
  • See the photo below for construction details: OEM cable is on the bottom, aftermarket cable on the top.
  • Click the button below for more information.
I had the same problem I have long tubes on my car and after 2 clutch cables in a little over a year and I took some heat shield tape and wrapped the clutch cable from the bracket on the framerail to the bellhousing. I dont know if it's the combo of the t-56 and long tubes combined but it didnt matter how I routed the cable it was always touching something.
Just looked at that MM clutch package with the firewall adjuster and quadrant. It says 82-04, anyone know why it won't work on 79-81? I have a t5 out of a newer v8 Mustang in my car so just wondering if its because the trans was different back then since it didn't have the 302 yet, or if there is something I don't know about :shrug:
It should bolt up fine. If the motor is the late model motor and tranny, the only thing i wonder would be the clutch quadrant under the dash, but i don't know. My main question is the OEM cable did not have the heat wrap, so why should the new cable but then again stock didnt have equal length shorties. is there a different way to route the cable away from the header. It melted above the bracket by the header not down by the bellhousing
