I have a t-5 transmission and i am in need of a new higher performance clutch than stock, but i dont know what one to go with, can someone help me please????
Depends on what flywheel you're using. Did you update the flywheel and clutch when you put the T5 in, ie, using 10.5 in clutch? Or did you keep the original, most likely a 10"?
That will depend on the flywheel you're running now. The older ones use a Long-style pressure plate, the newer ones a diaphram P/P plate. There's also 2 size clutch discs for small blocks, either a 10.5" or 11", if I'm not mistaken. Call Centerforce and see what they recommend.
