I need a torque qoute
  • Thread starter Thread starter steel1212
  • Start date Start date Feb 9, 2006
steel1212
1,180
Frankfort, Ky
Feb 9, 2006
  • Feb 9, 2006
Ok first of all no matter how I spell qoute it doesn't look right to me
Ok when my engine is done it will have the following:
afr 185s 58cc chambers
670 street avenger
224/232 0.555/0.565 roller cam
air gap intake
hooker headers
flow 40s
100-150 shot of Nitrous
What would be the max torque you think this engine would make with the nitrous? Moser rates their 28 spline axles to 5200. I only have desktop dyno numbers and NA it gives me 413 torque with the above combo. With 100 shot it says 626 and 150 shot 728 and there is no way its making that kind of torque. I need some real world numbers please! I'm useing this calculator http://www.moserengineering.com/Pages/axletech.html
xoxbxfx
3,959
Southlake, TX
Feb 9, 2006
  • Feb 9, 2006
you would be suprised how much torque giggle gas can give a motor. I would say your starting torque would be a bit lower than that. I would say real high 300's. Then a 150 shot will probably add close to 200ft lbs of torque. I dont like Desktop Dyno.. hasnt been to accurate compared to actual motors I have seen
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Feb 10, 2006
  • Feb 10, 2006
So do you just want a quote on how much torque you'll be making, or do you need it so you can decide what axles you need......or do have 28spl Moser axles and are worried they wont be enough?
steel1212
1,180
Frankfort, Ky
Feb 10, 2006
  • Feb 10, 2006
I'm tryin to decide if 28 splines will handle the power I'll be making or if I need to bump up to 31s. If I bump up to 31s I'm going to have to get a new carrier.
65ShelbyClone
4,675
38
119
Feb 10, 2006
  • Feb 10, 2006
I wish I could help more, but I dont play with nitrous. I suppose you could do a few dyno pulls and see where the torque is.
redhotcomet
103
Western Canada
Feb 10, 2006
  • Feb 10, 2006
Say 500 lb ft torque,
so (500 lb ft * 1st gear ratio * rear axle ratio) /2 axles
that should give you your max torque per axle, also you may have to multiply by your converters torque multiplication (if its an automagic)
D
D.Hearne
11,730
south louisiana
Feb 10, 2006
  • Feb 10, 2006
Don't worry about it. You're going to break that T5 long before the 28 spline axles. And only if you've got slicks on it and happen to get them to hook up right as you dump the clutch.
Edbert
3,548
32
109
Austin TX
Feb 10, 2006
  • Feb 10, 2006
You do not need a new carrier to change from 28s to 31s, i did it with mine.
I'd be very suprised to see 400+ ft/lbs of torque from a NA 302, I don't care what cam and heads you have.
I'd automatically subtract 15-20% from what desktop dyno says too.
xoxbxfx
3,959
Southlake, TX
Feb 10, 2006
  • Feb 10, 2006
i agree
AFR and Trickflow Head Information
  • 5spd GT
  • Aug 19, 2007
71K
Fox 5.0 Mustang Tech Apr 19, 2012
NIKwoaC
