  • SN95 4.6L Mustang Tech
i need advice!!!!!!
  • Thread starter Thread starter quickndslick2
  • Start date Start date Oct 13, 2009
Q
quickndslick2
Banned
Sep 28, 2009
24
  • Oct 13, 2009
i just installed the bbk long tube headers woth full magnaflow exhaust o/r x pipe and no catalytic, but it feels like something is missing, what else should i get? some people have told me to get thet cold air intake and thats going to help out alot? is that true? also should i tune the car on a dyno, or buy one of the performance chips? help me please thank you
stangman11
220
New Jersey
Oct 13, 2009
  • Oct 13, 2009
CAI, throttle body, intake plenium, and spacer is a great start that you will notice alot from, get that stang flowing better in and out.
Q
quickndslick2
Banned
Sep 28, 2009
24
  • Oct 13, 2009
iight dude thanks alott
banderss
Atlanta, GA
Oct 13, 2009
  • Oct 13, 2009
Your engine is basically a big air-pump. Anything that increases flow, theoretically, has the capability to increase your HP. Putting a larger, higher flowing, exhaust on your car will help getting that "air" (exhaust) out of the engine but if you can't get the air in you will really not see any improvement. Adding a CAI may help some, but your cams and heads are what's really determines how much air the engine can flow. Remember, there really is only one way, and one way only, to add HP and that is to add fuel. This is the premise a supercharger works under. Pushing more air into the engine allows you to add more fuel and still keep the correct air/fuel mixture. If all you do is the exhaust and a CAI, you'll need to get a programmer and do it yourself or take the car to a dyno and get it tuned. What gets you the extra few ponies there is to tune for the highest octane fuel available in your area and advance the timing as much as you can without causing detonation. It is estimated that you gain about 4HP/degree timing. BTW, for what it's worth, don't bother with a spacer...waste of money. Have one, had it on, took it off, makes no difference. A spacer that is a phenolic damper, or heat insulator, may possibly have some benefit by preventing heat soak into the intake plenum keeping intake temp. lower. Trust me, don't waste your money.
J
i need help
  • JK.
  • Oct 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
JD1964
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
M
Hey all
  • Mikalikey
  • Aug 20, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 20, 2026
Mikalikey
M
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
  • Gulftown980x
  • Jul 29, 2026
squeak93
