i need help finding a wire!!!!
superslothguy
103
ok so ive had my head unit in for a while and my friends and i cant find the memory wire its getting to be a real hassle to set all the stations constantly all i need to know is what wire is the memory wire please help :shrug:
Did you cut up your factory wiring or buy a harness adapter? If you bought the apapter it should be either the red or orange wire (I can't remember). which ever wire you have both your red and orange wire tied into to from deck now to your car is your ignition wire, the other is your power wire.-(be carefull this wire -I don't beleive-isn't intended to supply full power to your deck, its only meant to act as a "remote" turning your deck on and off. You could fry something if you keep it this way--possibly--maybe not just a thought), --If you went retarded (No offense meant) and hacked up your original wiring, all I can say is use a test light or multimeter to see which wires that are left over have power when car is off.
You can use any constant 12 volt wire with extra capacity for the memory source. Just toss a fuse on it for caution.
Good luck.
