yes it can be done if you are willing to do a ton of fabrication. you have to use the steering column from a similar car that has airbags installed, you need to a blow off panel on the passenger side, and a correctly sized airbag for that area. you then need all the airbag sensors, wiring, etc that goes with the system. THEN you have to be able to install the system, AND set it up to work in the stang. if you or your dad are engineers, then you could make the system work, if not then you are going to spend a ton of money getting someone else to make it work for you, and even then there is NO way to be sure the system will work properly, or even at all without testing the car as the factory does, running it into a concrete barrier at speeds above 35mph.
